Question about Neff 24 in. S5453X1 Built-in Dishwasher
My dishwasher is leaking from underneath, front left as you look at it. If i go underneath it, there appears to be a seal on the outside (it does not appear to be the one that runs along the bottom of the inside of the dishwasher) that has come away at one point. Do you know a) how to get the front panel off (the bit that makes it look built in),b) how can i get another one of these seals. I assume if i get one we can just fit it into place. Many thanks, Robyn J
  • Neff Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
p80897
Posted on Sep 29, 2010
GE Potscrubber,Quiet Power dishwasher leaks while running
Check to see if the door baffles are intact they are little black rubber things in the front on each side of the tub. the pump seal could be leaking underneath. the wrong detergent (dishwashing detergent) could have been used.
Oct 08, 2014 | Dishwashers
Dishwasher leaking
If its leaking from the front its the seal. Its probably dried out and got a crack in it. You could try to repair it with superglue or something but would be best to get a new one (seal or dishwasher you pick)
Apr 18, 2014 | Frigidaire FFBD2406NB 24" Built-In...
Water leaking underneath pitsos dishwasher when in use
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Jan 12, 2013 | Dishwashers
Leaking from the front
I had same problem but different model #.
The part under the spray arm came lose and the gasket was hanging out. Causing it to squirt water right at the bottom of the door and leaking out. I took it apart put the gasket back in the groove, screwed it back down and is working great.
May 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
Neff 24 in. S5453X1 Built-in Dishwasher Logo
195 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
