Question about Dell UltraSharp 2408WFP 24" LCD Monitor
My monitor, some how got stuck in an odd position, and now it won't move back to its original position.
Hit menu button on the screen located three buttons left of the power button. Select Auto Adjust. The display will automatically adjust the screen to the centre. If your display is like mine, you may have to repeat these steps several, several times to correct the problem.
Posted on May 31, 2010
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
Help, my Asus Essentio CG5290 won't post after moving.
check the cable for the bad monitor at BOTH ends. Some cables detach from BOTH ends, and if one side is lose, then you will get weird stuff happening....odd colors, lines etc.
Otherwise...it would seem to be a bad cable....which would **** if it is one of those that does NOT detach from both ends.....since you can't just go get another monitor cable.
Tallon41
Sep 16, 2012 | ASUS Essentio Computers & Internet
Why won't this machine work
Bobbin case might be jammed in an odd position or thread is locking mechanism and wont move hence "the buzzing" sound
May 11, 2012 | Euro-Pro 9130 Sewing Machine
My monitor is stuck on a webpage!! The mouse won't move,I turn it off and back on and it is still on the same website?
It's not the monitor that's stuck - it's the PC. Press and hold the power button of your computer for about 10 seconds - this should force the computer to turn off immediately.
When you turn it back on, it will tell you there has been a problem, you can normally skip any errors that come up, and choose "Start Windows Normally". and it will return as normal.
Aug 05, 2011 | Hannspree Computers & Internet
Gear got stuck in nuetral, and in park position in the dashboard and the vehicle won't move--this is my problem on my 2003 trailblazer suv.
It may be the gear selector switch on the tranny where the linkage bolts on its a odd shaped plastic peace you can see if its broke or loose.
Jun 26, 2011 | 2003 Chevrolet TrailBlazer
Stuck key in on position,how to remove and replace cylinder
Before you do that. Try moving the shifter a few times from drive back to park. Sometimes these switches with the transmission won't allow you to return the cylinder to the complete neutral position if the park switch doesn't engage.
Jun 13, 2011 | 2001 Chevrolet Cavalier
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
Power button stuck in off position on Dell Flat screen Monitor
Does the button move at all? What model LCD is it? Most of the time if the monitor does not power up it is the power supply inside the monitor not the button sticking. The power supply can be repaired if that is the problem. Please let me about the movement on the power button and I can help you get back going with your monitor.
Buddy
Corporate Computer
Jun 17, 2009 | Dell E176FPC Monitor
IT IS STUCK , IT JUST HUMMS ,CYCLE DOES NOT START
I PULLED THE DISHWASHER OUT FROM UNDER MY KITCHEN TOP. THEN TRIED IT AGAIN AND IT STARTED WORKING. WATER WAS ENTERING THE MACHINE AS IT SHOULD AND THE WHOLE CYCLE WAS COMPLETED FROM WASHING TO DRYING. BUT WITH THE ODD RATTLING SOUND NOT COOMING FROM DISHES. I ASSUME THE INLET PIPE WAS PROBABLY BENT THEREFORE BLOCKING WATER COMING IN BUT WHY NOW AFTER YEARS OF BEING IN THAT POSITION. THE OTHER THING I CHANGED WAS THE ELECTRIC SOCKET POINT- IE I PLUGGED IT IN SOMEWHERE ELSE BECAUSE MOVING IT MEANT THE LEAD COULD NOT REACH ORIGINAL SOCKET. HOPEFULLY WHEN I RETURN IT TO ORIGINAL POSITION EVERYTHING WILL BE WORKING. FUNNY THING HAPPENED THE WEEK BEFORE- MY WASHING MACHINE WAS STUCK IN MIDDLE OF A CYCLE . BUT STARTED WORKING THE FOLLOWING DAY. COULD IT BE MY ELECTRICITY PERHAPS - IE MY APPLIANCES ARE NOT RECEIVING ENOUGH CURRENT?
Dec 04, 2008 | Dishwashers
Dell UltraSharp 2408WFP 24" LCD Monitor Logo
128 people viewed this question
Alun Cox
