My HP Deskjet D4260 printer has started to print v-e-r-r-r-y slow, approximately 1 line per minute. This printer is connected to a Dell computer with Windows XP. I have done an updated download from HP with no difference in results.
  • mfoust Apr 29, 2010
    I confirmed that there is plenty of memory.
    I disconnected the printer from the computer, restarted the computer, re-attached the printer, used a different USB port.
    Rylee,
    Thanks for the suggestions. Before I start, could you clarify the last statement in the list; namely what does "hold down #7" mean?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. If still the issue is not resolved then please follow this:
1) With the Printer power on open the door so that print heads move to the center.
2) Unplug the printer, kindly make sure to unplug don’t turn it off.
3) Open the back door.
4) Look inside the back left side for a small black gear (About the size of a quarter)
5) Spin the gear with a screw driver (I'm pretty sure I spun it clockwise). Spin it and watch the inside of the printer where the print heads park. You should see a tray move out that has four rubber blue rectangles on it on the right side of the unit (this is where the print heads park when the unit is not printing).
6) Keep spinning the gear until the plate moves all the way forward.
7) Grab the plate and try moving it forward more.
8) Put the back on and close the top.
9) Turn the unit back on.
10) Open the top again
11) Unplug the unit again. (Don't turn off, just unplug!)
12) Grab the tray, from step 5, and slide it all the way forward and all the way back multiple times.
13) Make sure that the print heads slide left to right smoothly
14) Remove ink cart's and clean the contacts with bottled water and a q-tip. LET DRY BEFORE REINSTALLING!!!
15) Remove print heads and clean contacts with bottled water and q-tip. LET DRY BEFORE REINSTALLING!!!
16) Clean the inside of the printer with a soft dry cloth, use a slightly damp, with bottled water, lint free cloth (Glasses cleaning cloth works well) and wipe off the rollers in the front and back of the unit. See HP's cruddy support site for details on this step.
17) Hold down #7 (reprimes the printheads with ink) and plug in the unit
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 29, 2010
  • Rylee Smith
    Rylee Smith Apr 29, 2010
    You can leave that and instead hold start button.
    Guru:
  • 1,049 Answers
This is a buffering issue. Two things that can cause this are a lack of drive space and a corrupted driver.
1. Drive Space. You need at least 200MB free on the drive to be able to print without issues. You can check the drive space by opening my computer and clicking on the C: drive. The free space should be listed on the left side of the window.
2. The Driver. Updating the driver does not necessarily remove or replace all the files. Many settings and files are locked into the windows system. To fix the driver. Uninstall the printer completely. Disconnect the printer from the computer, restart the computer and reattach the printer after the system fully loads (if USB...use a different USB port). Finally, let the system detect the printer and setup the printer using the newest available driver. Ideally you want to point to the INF file in the driver folder and set it up through Windows, not run the setup installer.
Posted on Apr 28, 2010
Printer HP deskjet D4260 status off line...how to make on line status?
connect you printer in your computer and install your driver.. then open your printer.. if this doesn't work may be you have a cord problem..
Apr 18, 2011 | HP Deskjet D4260 Printer
Deskjet D4260 appears to start printing but is only throwing out blank sheets
This might appear that you have the incorrect drivers installed. try updating the driver. You can usually get it from the HP website.
Mar 07, 2011 | HP Deskjet D4260 Printer
My hp deskjet printer d4260 is not printing when i send i print job to it
if you have updated drivers from HP, Uninstall them, and install the drivers from the original CD that came with the printer. the updated drivers from HP don't work well with Windows 7.
Feb 27, 2011 | HP Deskjet D4260 Printer
Hi ! When I install my HP product I get at connecting my HP print but I don`t know what to do. Please help me.
If you connect your hp printer to the computer, it should install the basic drivers available from the Internet, which hopefully will be automatic. If it doesn't install automatically, then you'll have to manually download the correct driver for the hp deskjet d4260 inkjet printer.
In most cases, the printer will be connected physically with a usb cable. One end goes to the back of the printer, and the other goes to the back of the PC.
Good luck on this.
Jan 01, 2011 | HP Deskjet D4260 InkJet Printer
When I try to print with my HP D4260 printer, it will not print solid colors - everything has banded lines. Can I fix this?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Deskjet D4260 Printer
Hi , my printer hp deskjet d4260 does not print. There is ink and paper in the printer but whenever i try to print something it doesnt work. When i did chang the ink it still printed the paper for...
1. goto control panel -> printers.
2. delete the unnecessary printers including your D4260.
3. Use the driver cd which came along with your printer and reinstall all the software and drivers again.
4. Now you should be able to print without any problem because in this way all the driver conflict or corrupt printer files will be fixed.
I hope this is helpful to you
thanks
Sep 23, 2010 | HP Deskjet D4260 Printer
I HAVE A D4260 DESKJET PRINTER THE RESUME LIGHT IS CONSTANTLY FLASHING IT HAS PAPER BUT WONT PRINT A THING HEEELLLPPP!!!!
if light is constantly flashing, printer is not print.
printer on and all papers out in printer and light is always on than paper in and print.
Mar 01, 2010 | HP Deskjet D4260 Printer
Only prints black and white,it has two new cartridges hp deskjet d4260
You could try to do a power down reset and reinstall your cartridges.
First turn off computer
remove the 2 ink cartridges,
press power to turn off printer
unplug printer from ac outlet
wait 3 minutes
plug back printer
turn on printer
wait until printer stop
reinstall both cartridges
turn on computer
Dec 03, 2009 | HP Deskjet D4260 Printer
Printer won't print
HI
Try to unplug the printer and then plug it back
Jan 27, 2009 | HP Deskjet D4260 Printer
jasbo
jasbo
