Samsung SGH-A877 Impression Cell Phone Logo
Posted on Apr 28, 2010
How do i mute keys when texting - Samsung SGH-A877 Impression Cell Phone
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
216
Points
6
From the home screen click on the menu button - then click settings - scroll down to audible touch tones if this has a check mark in it remove it and this should work.
Lenovo keyboard ku 0989
This is a setting you may have to change on your computer and not the keyboard. Reboot your machine and enter your BIOS (sometimes called Setup) there is usually text in the corner of your screen when you first turn on your computer that says "Press F2 for setup" If not, google how to get in. Once there, you need to find the setting for F Lock (depending on your computer, it may be called ActionKeys, who knows -- you can google that first) and change that setting. Sometimes you have to enable it and sometime you have to disable it. Either way, the F Lock will be toggled and the F Keys should function normally and you'll have to press the Fn key to get Mute.
tip
NOKIA E71 Tips and Tricks
The E71 was one of the very best handsets to come out of Nokia factories in 2008 and the best ever in my book. So it is only right that we utilise its functionality to the absolute hilt and try and make the E71 even more efficient.
Here is a long list of must know tips and tricks for the E71. You might already know a few but if you are new to S60 and the E71 in particular, I’m sure this will make for a happy start to the E71 new year!
  • STICKY FUNCTION KEY – A quick double press on the bottom left ‘function’ key locks it. This is helpful in situations when you need to press a combination of keys or in applications like Gmail which can be controlled via the keypad.
  • 1-800-WHATEVER – To dial 1-800-WHATEVER: type 1800, hit Fn, then Shift twice, type WHATEVER, and press the Call/Green key to dial. (The idea is to type in the alphabet mode in CAPITAL letters ONLY). The alphabets will automatically be converted to numbers.
  • ONE TOUCH MUTE – You can simply mute a call by press the button between the volume keys present on the right hand side of the phone. Press it again to cancel the mute.
  • REMAP THE KEYS – There are times when you feel certain keys on the E71 are being wasted when they could have come in very handy. For example, the volume keys would work wonderfully with the web browser to scroll pages or in your music player and the mute key could work as select. Make that happen.
  • TIME & DATE – When the phone is in the locked state and the screen is blank, hit the Navi Button to display the time and date in a large font.
  • TEXT MESSAGES – When in the standby mode, hold down left soft key to read out new text messages.
  • ASSIGN SHORTCUTS - If you have a lot of applications installed on your E71, you might want to assign additional shortcuts to different applications by definying a set of keypresses with an application called Cute Keys.
As a follow up to the above tips, here are a few shortcuts that you should enjoy. I have highlighted some of the lesser known ones.
GENERAL
  • To get to a symbol or number hold down its key.
  • Shift + Backspace deletes letters after the cursor, thus immitating the behavior of the ‘Delete’ key on the computer.
  • In the Main Menu:
A B C D
E F G H
I J K L
To open A press 1, 2 for B, 3 for C, * for D, 4 for E, 5 for F and so on.
* Fn + Ctrl + C to copy.
* Fn + Ctrl + V to paste.
* Shift + Left ( or Right ) to select text.
* Ctrl + Up for page up.
* Ctrl + Down for page down.
* Ctrl + Vowels ( or n ) for accented characters like á or ñ.
CAMERA
  • T to focus.
GALLERY
* Green Call to send the image.
* Fn + * for full screen.
* Fn + 7 to zoom in. Press twice for the full screen size.
* Fn + 4 to scroll left while in the zoomed image.
* Fn + 5 to zoom in.
* Fn + 3 to rotate right.
* Fn + 2 to scroll up while in the zoomed image.
* Fn + 1 to rotate left.
* Fn + 0 to zoom out.
STANDBY
* Hold * to activate/deactivate Bluetooth.
* Hold 0 to go to the web browser.
* Left Soft Key then Fn ( or * ) locks the keypad.
* Hold End/Red to disconnect all data connections.
* Hold Left Soft Key to read out new text messages.
MAIL
* Shift + Return to mark/unmark a single message.
* Shift + Down to mark multiple items.
* Fn + Spacebar in new message body to access input (predictive text, etc.) options.
MAPS
* Shift to zoom in.
* Backspace to zoom out.
* Space to go to the current position.
REAL PLAYER
* Fn + 2 for full screen.
* Hold Up for fast forward.
* Hold Down for rewind.
WEB
* 1 for bookmarks.
* 2 to find something on a page.
* 3 to return to the previous page.
* 5 to tab open windows.
* * to zoom in.
* # to zoom out.
* 8 for page overview.
* 9 to go to a different web page.
* 0 to got to the homepage.
* Hit the Backspace key to close the current window.
on Dec 15, 2009 • Nokia E71 Smartphone
The keys on my Samsung phone how do I get it on mute sounds driving me mad when try to text
Please post your phone's model number. All that you have included is that you have a Samsung phone, we need to know which phone you have.
1helpful
Blackberry 8310 mute key
mute is on the menu when you're on a call. Third one down, I think.
While the BB is ringing you can press the top button and that mutes the ring
2answers
HP probook 4420s stuck on mute
Look on you system at the keyboard and you will find a key that toggles the mute if he pressed it. It will toggle between on and off. Normally the mute key or button will look like a megaphone and if it is muted it will have an x over it. Press it to unmute it. Sometimes if it is a key, you might have to press the FN, CTRL or ALT key while you press and hold the key that toggles the mute.
Another way to remove the mute is to Double Click on the megaphone if you see it at the bottom right near the time. This will bring up the volume control and you just remove the check mark from any that is muted.
Also you can click Start/Control Panel look for volume controls that might be muted and remove the check mark on mute.
Also click Start/Programs/Accessories/Entertainment/Volume Control and remove the check mark on muted items.
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
1helpful
My wifes samsung tocco lite mobile keeps bleeping when texing or touching the screen we have lost the manual can you help
With the keypad on screen - press and hold the hash key which also mutes the bleeps. This will mute everything, so remember to repeat this process when you have finished texting otherwise you won't hear incoming calls.
Sep 23, 2010 • Cell Phones
1helpful
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
How to remove text display on TV screen
I have an older standard Fisher TV, model no. PC1527. The text displays that state, "NEED SETUP PRESS SETUP KEY". I press it and nothing happens. What am I doing wrong. Please help, I want to remove this and other displays like the mute and sound lettering.
How to select Texting
I just got my Vizio 32" a few days ago, so this is fresh in my mind. When the tv is on and TV is selected from the top row of remote buttons, press MENU. Use the arrow keys surrounding the MENU button to select the WRENCH icon. Under this icon use the down arrow (surrounding MENU) to select CC. Use the right arrow to choose CC ON MUTE (closed captioning only when you select the MUTE button on remote) or CC where you can use the arrow key to change OFF to ON and closed captioning will be on all the time. Hope this helps!
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
