Question about Fuji Finepix A610 Digital Camera
I have a Fujifilm FinePix A610 camera. This
I have a Fujifilm FinePix A610 camera. This started happening recently: I turn the power on, the screen lights with the Fuji icon, the zoom lens extends and the camera shuts off with the zoom lens extended. I tried new batteries but the same thing happens. The lens retracts when I plug it into my computer.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
Showing date on pictures from finepix A160
Is this information not contained in the camera manual ?
Oct 04, 2016 | FUJIFILM FinePix A610 6.3 Megapixel...
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Jan 01, 2016 | FUJIFILM Cameras
My fujifilm camera fine pix a610 won't work i've had it for quite a bit of time and i only just turned it on in ages and it won't turn on. i am using kodak batteries
Because you haven't turned it on in ages the battery has probably died. Try connecting the camera directly to the power adapter without the battery. Does it turn on then? If so then the battery is the problem and you need a new one. You can get a new one from here
Mar 05, 2011 | Fuji Finepix A610 Digital Camera
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
The screen on my A610 is blank, but I can still take pictures with it but can't see what I'm viewing! Help!
Check the display button. It may be toggled to be turned off. Can you see pictures when on playback? If not, you screen is dead.
Jul 02, 2010 | Fuji Finepix A610 Digital Camera
User Manual A610
You can download a manual from http://www.fujifilm.com/support/digital_cameras/manuals/
Jun 24, 2008 | Fuji FinePix S5000 Digital Camera
Fujifilm A610
Try this solution: http://www.fixya.com/support/t143152-fuji_zoom_error_message
Jul 09, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Fuji Finepix A610 Digital Camera Logo
192 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
