Question about Toshiba Tecra 8000 Notebook
Replacement laptop hard drive
All i want to do is replce a faulty hdd on my old laptop, but trying to pin down the connection type is a pain,
Is it ide/ sata or what?
  • scotty66 Mar 29, 2008
    Already thought of that, but not currently able to get to a local showroom. Plus am trying to source replacement from the web!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
First you remove the old hdd from your laptop take to the showroom and tell him to give the exact drive
Posted on Mar 24, 2008
When installed the HDD spins but the PC does not recognize the HDD. Not in BIOS, not thru the DOS-prompt or in sys configure/hardware or HDD configuration. It also interfers with the startup of the PC and...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
Mar 15, 2011 | Hitachi Travelstar 5K500.B...
Hello, my Hdd drive was died after falling down in turned off condition. when turning on, system sometimes views it, sometimes not, and if views, can't loads it, i have tried to format it with partition...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 24, 2011 | Samsung Spinpoint MP0402H 40 GB Hard Drive
I have laptop fujitsu-siemens Amilo M1435G, I want to re-install the windows XP, but when I boot the system from the CD Rom after loading the files there is coming an information that HDD not detected...
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 12, 2011 | Fujitsu Siemens (MAN3184MCB) Hard Drive
Hi, I have a problem with overheating (I think) acer aspire 1355lc notebook.... I have replaced the fan, HDD, and thermal paste, but it shuts down completely bang after just a minute.... what to replace...
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Acer Aspire 1355LC Notebook
In my compaq v3000 other 120gb hdd detection is ok but when i connect wd1200bevs then their is no hdd detect in cmos setup, hdd works very fine on usb hdd connector.
hope this helps
Jan 20, 2011 | Western Digital Scorpio WD1200BEVS 120 GB...
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Screen does not come on . cylinder shaped light (by the power light and on/off light) is not lighting up.
Sound like your Hard Disk drive is not starting up. They are normaly easy to replace, but i would try removing it & putting it into a hdd caddy, there is 2 types, 1 is the old IDe connection & the other is the Sata connection the bigger of the 2 is the IDE and has 2 lines of pins the Sata is normaly a female connector on the drive.
If you can get hold of a caddy insert it & connect it to a freiends pc or laptop to see if it works, it saves buying a new hdd if its not faulty.
Nov 08, 2009 | ASUS Eee 4G Notebook
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Thankyou
Jun 17, 2008 | HP Pavilion dv9000z Notebook
Dell laptop hard drive.
I have never seen a 2.5" drive without the missing pin. It is there to ensure the drive is not connected upside down. I think I would return the new drive if all pins are there. If I couldn't return it then I would think about cutting the unwanted pin after very careful counting.
Jan 20, 2008 | Dell Latitude C600 Notebook
Toshiba Tecra 8000 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
