Question about Lenovo M58P USFF-ECO E8400 1GB/160 DVD WVB (7479A4U) PC Desktop
Bsod booting off of a cd on Lenovo M58p - Lenovo M58P USFF-ECO E8400 1GB/160 DVD WVB (7479A4U) PC Desktop
  • lsaslaw Apr 28, 2010
    i am getting BSOD when trying to boot of a BartPE cd so that i can save the image up to my server. I have already spent much time getting the SATA drivers installed. Now, can't boot off of the AHCI CD device.
  • 560 Answers
BSOD can be hardware & software error. Since you are only booting to a CD, it can't be software. I haven't encountered BSOD as a result of booting to a CD.
Power off the machine and unplug from the power outlet. Remove all expansion cards and memory modules. Clean the contacts of the cards and memory modules with pencil eraser and wipe with clean-dry-cloth.
Insert the memory module and video card (if not built-in) then power on the machine and boot to CD. If successful, re-insert other expansion cards one by one to isolate the source of BSOD. Don't forget to power off and unplug the PC each time.
If you are installing to HD and you still get BSOD, try to change your HD and memory modules.
BSOD can be a result of
Posted on Apr 28, 2010
  • 15,935 Answers
What is your issue/question?
Thanks!!
How to cd boot lenovo 7479
as the system turns on, keep hitting the F12 key until the boot menu appears. select CD
Apr 28, 2014 | Lenovo Group Limited Lenovo ThinkCentre...
M58P 6234 A1U
dear sir,
my machine mod.no.ams 210d hs
machine problam is err..no (axcept redy pogition) board heated disply
Oct 27, 2013 | Lenovo Thinkcentre M58p 6234-A1u Pc - Win...
No video output
If your LCD TFT has both a DVI and a standard VGA video input then you need to select the correct video input on your monitor.
Dec 02, 2011 | Lenovo ThinkCentre M58p 250GB HDD PC...
I got a Lenovo ThinkCenntre M58P with Win7 64-bit OS. If I had a power failure the machine doesn't startup from the HDD as it gives an error that it cannot see the OS. When you check in the BIOS, the...
Reconnect both connection to harddrive then when you power up the computer press F8 key 5 to 6 times untill you see the safe mode and other menu if you are able to enter in safe mode then os still fine run 'chkdsk /r" in run but if you are not able to enter in safe mode or same error then need to check with bootable windows disk insert that disk set first boot device as cd/dvd rom then boot with windows disk then follow the procedure if it able to see windows then repair it .then it will working again. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2011 | Lenovo ThinkCentre M58p 250GB HDD PC...
BSOD says boot partition is full, when it isn't
hello
try to boot in safe mode.(press F8 after bios bootup)
if that doesent work run chkdsk.(boot from windows cd and choose R(repair mode) go to the console and write chkdsk /R let that run and try to restart when its done.
Feb 23, 2009 | Lenovo ThinkPad R51e Notebook
I want to install XP in lenovo y510
okie! a question? i have installed windows Xp with Sp3 on my Y510. Now whenever I try switching back to AHCI mode i end up with a BSOD. would it make any difference if i leave it in the compatibility mode? or how can i get it back to AHCI mode
Feb 17, 2009 | Lenovo IdeaPad Y510 Notebook
R3000 Compacq laptop wont boot up
Hi.
Can you please give me full details on what the problem is, the BSOD, does it appear after the boot is finished and loading the OS?
Does the OS start and then get the BSOD, ETC.
If You have the original install cd, enter your bios and at BOOT DEVICES [OR BOOT SETTINGS] make sure that the first device to boot from is your cd/dvd etc, Put The Cd of the OS in the cd/rom and restart the machine, it will hopefully start the instalation of windows do not tell the program to install a fresh copy, but rather use the R for repair.
If that does not work or you still have problems it sounds like it's time for a new instal of windows, the BSOD [Blue Screen Of Death] pops up when files get damaged, if you overclock without checking everything voltages, fans, TEMPERATURE of CPU etc.
Also can you please tell me how long ago the system was activated, and what if anything did you do or were working on when you got this BSOD.
What the OS you are using is can help also, and is it sp1? sp2? sp3? for win XP even vista is up to SP1 already for a supposed new os from ms.
HTH
Zues
Dec 21, 2008 | Computers & Internet
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
See all Lenovo M58P USFF-ECO E8400 1GB/160 DVD WVB Questions
Lenovo M58P USFF-ECO E8400 1GB/160 DVD WVB (7479A4U) PC Desktop Logo
32 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
