Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Direct tv my screen is blue and on the bottom of the tv it says channel is off air or does not exist, please help
    Sergeant:
  • 395 Answers
You are on the tuner input, select the input for your directv sat box. use the mitsubishi remote and select the desired input.
Posted on Mar 24, 2008
I now have a roku account but did not see where I could enter the code!!!
Well your just about to be set. Like almost. The activation code must be entered either on www.owner.roku.com/link or if you have an existing account go to www.roku.com then hit "please sign-in", then under "my account" page scroll to the bottom of the page look for a blue rectangular box that shows "link a device". click on that then you get to see the activation box where to input the code you see on the TV screen. Once accepted hit "continue" on the next page its at the bottom of the screen (dont add any channels yet). After that page you wi;; see "congratulations happy streaming". Check the TV screen because thats it, the channels on your roku player will be updated.
Sep 15, 2014 | Roku Streaming Stick
We have a new Philips 32" LCD TV, 3500 series/32PFL3505D. We are having problems as we try to connect it to our existing Direct TV receiver. Do we need to call for Direct TV assistance, or can you...
Looks fairly straightforward.
Depending on the output of your DirectTV receiver, you are either going to use an HDMI cable.tomcattech17_0.jpg
A component cable: (Red\Green\Blue for video... White\Red for audio)
Or a composite cable: (Yellow for video.. White\Red for audio)
Hook one side of the cables to the Direct TV receiver and the other into the correct inputs on the back of the TV.
Page 9 and page 25 in the attached manual:
http://download.p4c.philips.com/files/3/32pfl3505d_f7/32pfl3505d_f7_dfu_aen.pdf
Hope this helps!
Jun 16, 2011 | Philips Televison & Video
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
Jan 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
2005 sony 55'' sony wega. a very thin blue line is
Are you using a cable or sat box. If so then you are selecting channel using the tuner in the box and sending a constant signal to the TV eithir on one channel of the tv tuner or one of the other input of the tv. If this is the case I would suspect the box and not the tv because you say it is only on some channels.. If you are using the tuner in the tv with cable or antenna directly in I would say the main board that has the tuner on it needs replaced. Without a specific model number thats the best I can do. Hope this helps.
Nov 25, 2009 | Televison & Video
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
