Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Error code C-0500 - Konica Minolta bizhub 350 All-In-One Laser Printer
    Guru:
  • 571 Answers
On the control panel, Check the right side of the panel if there a hole, and press it w/ a paper clip, it will reset the code, if not. It need a new fuser unit
Posted on Apr 28, 2010
How to fix fuse failure code 0500 phaser 6121 Xerox
0500 is a fuser failure error. Need to replace fuser.
http://www.iteminconline.com/126e02770_126e02770-xerox-6121mfp-fuser-110v-new.htm
Nov 15, 2015 | Xerox Office Equipment & Supplies
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
0500 ERROR CODE
I am also facing this trouble, with Di3510. some time machine work for many copies fine. then suddenly the 0500 error code appear. I checked complete fuser unit... Both lamps are ok, Thermo switch is ok, i checked both thermistors and in my view they are ok (checked with multimeter while warming them). I first reset the code as mentioned in the service manual of this machine. the code can remove but it comes back after some time. I checked the Electricity voltage as this machine is 120v input. Voltage are ok. Then i ask my Electronic board expert to check the Power supply and he told me that the power supply is ok... just some dry sold he found. So until now i am not able to detect the trouble even though i arranged another fuser unit of the same machine and it also gave the same error code c0500. As i am a Technision of copiers. Please give any good suggestion if any one have. Thanks
Jan 09, 2014 | Konica Minolta DiALTA Di200 Copier
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dialta di450 Error Code C-0500
Fuser unit problems.Check fuser lamp in the upper and lower fuser roller,check the termofuse & termistors.
Jul 29, 2009 | Minolta Office Equipment & Supplies
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Minolta EP1030/1030F CS/PRO Copier
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
149 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
