Question about Brother IntelliFAX 2800 Laser Fax
Machine has a error code of 77 and said to phone Brother - what does this mean?
  • 525 Answers
Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the top cover is
opened and closed, or the machine exits from the sleep mode.
Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby
Posted on Jan 23, 2011
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Machine is on and showing "error message #77 and says to unplug machine and call dealer. What is error 77?
Error #77 refers to a mechanical problem, but I'd say about 7 times out of 10 it's a mistake. Fortunately, Brother fax machines have override commands :). Try this:
1. Turn the power off and unplug the power source.
2. Press and hold the menu button and plug in the power source (don't let go of the menu button!).
3. Hold the menu button for 5 seconds after plugging in the power source.
4. Release the menu button and press "91"
5. If the screen still shows the error code, press "99".
Hopefully this will override the error and you can get back to work :) .
Hope this helps! Good luck!
Aug 30, 2010 | Brother IntelliFAX 2800 Laser Fax
Machine error 77
Hello there, in a situation like this the best thing for you to do is to call Brother customer service at 800-284-4329 and explain the problem.
Thank you
Jul 16, 2010 | Brother IntelliFAX 2800 Laser Fax
Error 77
Error 77 is fuser error . Shut off the power for 20 minutes . If that didn't reset the unit , then you need a new part . Call the local dealer to ask about new part price .
please rate !
Apr 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Message on machine states error 77, unplug and call brother?
Error 77 basically means- Heater thermistor short circuit. However, the message is sometimes incorrectly shown. You can try this- power off the machine, take out the cartridge, close the door and power up. The machine should notice either the toner or the front door is not in place. Now open the door and place the toner. This might solve the problem. You can also try to soft reset the printer. If none of these works, you might have to change the thermistor.
Apr 06, 2010 | Brother MFC 9700 All-In-One Laser Printer
Getting a error msg 77 ?
Your Heater Thermistor most likely short circuited. It's a $10.00 part, however, you will want a Brother ASC to replace the part as it requires you to take most of the machine apart. Call your local Brother ASC by searching Brother's Website http://www.brother-usa.com/service/default.aspx enter your printer info and your zip code.
Dec 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
90 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
