Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Everytime I wash a load of clothes the washer turns off right before it rinses . All I have to do is push the start button and it goes to the rinse cycle. What could cause this to happen?
  • Anonymous Mar 13, 2014
    maytag washing machine won't spray rinse
    Problem Solver:
  • 3 Answers
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Posted on Apr 13, 2008
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Didn't rinse properly, the'res more soap left on clothes as well as clothes small parts are still left on clothes after rinsing
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    The washer will not complete the wash cycle. Lr
    http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
    If all else fails, replace motor control board, and/or motor.
    Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune stops in mid cycle
    It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
    Feb 28, 2009 | Maytag MAH20PD Front Load Washer
    Maytag neptune washer washes, drains but doesn't spin or rinse. open door to find wet, soapy clothes. Thanks
    Read along in the threads/posts on the same topics. I posted a lengthy reply that has worked for me numerous times
    Dec 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune rinse cycle doesn't start.
    cold water valve screen plugged or bad valve, just check it!
    Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Detergent goes where?
    3 - Select Cycle
    This is according to the owner's manual I have. Has worked for 9 years for me.
    Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
    Maytag Washer Not Completely Rinsing
    If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
    Just a suggestion.
    Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
    Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
    Oct 25, 2007 | Washing Machines
    Maytag Neptune MAH5500B Front Load Washer Logo
    621 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
