Question about Sewing Machines
Bobbin winder on Brother XL2230 not working properly; hesitation in that area is causing bobbin to wind erratically.
    Genius:
  • 1,116 Answers
You can take the machine in for service or purchase a Sidewinder Bobbin Winder.
Service begins around $60 plus parts and the Sidewinder is less than $30.
Posted on Apr 28, 2010
Bobbin problems winding
Does the bobbin winder have a rubber o ring on it so that when the winder is in the winder position are the two making contact to wind
Mar 14, 2014 | Sewing Machines
How to remove brother XL2230 sewing machine case
Take off the panel that conceals the lamp (see your instruction manual) and you will see another screw that needs to be removed before you can take the larger back panel off.
Jun 15, 2012 | Brother XL-2230 Mechanical Sewing Machine
Broken bobbin winder
For $29 at Hancock, Jo Ann's or Wal Mart you can get a thing called a Side Winder that will wind your bobbins without using the winder on your sewing machine. It has the additional advantage that you can wind while sewing. I use it even with machines that will wind bobbins.
Feb 25, 2012 | Brother XL-2230 Mechanical Sewing Machine
Help me !!!!! Got a brother XL2230, bobbin winder broken
Hi, I have the same problem, use a car 'o' ring that should fix it, should cost about
May 20, 2010 | Brother XL-2230 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
294 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
