Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Would not take a charge. Dealer said to buy new batterys so we did. Said it was charging but whe you hit the button all light flash on and off 3 or 4 time then it quits. still won't run. Chair has been used very little. Less than a mile on it.Can you help? battery went dead over the winter. chair two years old and like new. Charger says battery is charged.
  • vanishme Apr 28, 2010
    Batteries went dead over the winter. Bought new batteries and installed them. Charged them and when you hit the on button lights on control flash about 5 time then go out . Chair has not been run more than a few hundred yards since bought. It has to be something simple as chair is like new. any ideas? Seat was taken off to reach batteries and put back on.
  • vanishme Apr 30, 2010
    The chair has new bateries in it and they are charged up. When you push the power button, lights on control flash on and off several times quit and then do it again. The charger is new and working. the batteries are new and charged. Chair won't move.
    Genius:
  • 1,400 Answers
Hello
Is there a reset switch on this chair? OR possibly a saftey switch locking it out.
I know some chairs have a device to shut it off when on unlevel surface.
Consult owners manual for any kind of lockout os saftey switches.
You may need to do a reset.
Posted on Apr 30, 2010
    Top Expert:
  • Pride Master
  • 79,186 Answers
YOU NEED TO HAVE THE BATTERY CHARGER TESTED, ANY RADIO SHACK OR DEALER FOR THESE TYPE OF ELECTRIC CHAIRS CAN TEST IT AND GIVE U THE REPAIR COST IF IT IS DEFECTIVE, ALSO MAKE SURE ALL THE CONNECTIONS TO THE BATTERIES ARE CORRECTLY HOOKED UP AND ARE CLEAN AND PROPERLY TIGHTENED, IF U ARE NOT SURE TAKE IT TO A DEALER AND HAVE THEM TAKE A LOOK, THEY WILL DO THAT IN MOST CASES FOR FREE
Posted on Apr 28, 2010
    Guru:
  • 1,049 Answers
Assuming the charger is good. There is most likely a problem in the controller itself or the motors, possibly a short. This will have to be addressed by a certified repair professional.
My nextbook 8 has a red flashing light and wont power on even after charging
Try taking out the battery and try turning it on with it plugged in. If it works, you need a new battery.
Jan 03, 2014 | Computers & Internet
The nintendo DS is flat. Whe I attempt to charge it the light flashes orange and then goes off?
That usually means that the ds is fully charged. If it is not charged then there is probably a problem with the battery or the charger.
Feb 24, 2011 | Nintendo DS Lite Console
After charging the Battery the power button flash blinks
i think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
Sep 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Dual shock controller will not hold a charge or sync with my PS3
If it has Ni Cd batteries, You probably charged it to early. They have a "memory effect" which means if you charge it when it half dead, it will have less charge next time. You can buy new batteries, or go to Radio Shack and get them revived. OR:
http://www.instructables.com/id/Revive-Nicad-Batteries-by-Zapping-with-a-Welder/
Just remember: Buying batteries would be a better idea.
Jul 23, 2009 | Sony Dual Shock 3 Controller for...
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
No electrics following battery charging
you will need a test light to actually test fuses,because they can be deceiving from visual inspection.
Dec 07, 2017 | 1994 Porsche 911
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
57 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
