Question about Minolta CF2001 Copier
It was in the middle of a print job, when it stopped and showed Malfunction Detected Provide code C-OF36
  • 1,110 Answers
C-OF36 means that the mahine is not getting black toner properly. Specifically the service manual says:
"Abnormally low toner density detected by Black ATDC Sensor. Toner density that is 2% or more lower than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence."
What this means in simpleterms is that the machine is trying to add black toner and is not getting it.
Have you tried turning the machine off then back on to reset the code and see if the machine can add the required toner?
I would try this a few times. If it does not work then you will need someone to come out and service it because there are numerous causes for this condition and most are going to require dis-assembly of components to locate the problem.
Good Luck and Thank You for using Fxya!
Posted on Apr 28, 2010
My HL 2270DW won't stop printing goobldegook. One or so lines on each page, and the printer job does not show in the cue so it can not be cancelled. I can not print any jobs because of this malfun
Has it worked before? Many of these newer printers can print what are called Postscript documents, and you may have a Postscript driver instaled instead of the regular driver, or both and have selected the wrong driver when sending the job ORyou have an internal circuit board that'sgone bad
Jan 07, 2013 | Brother HL 2270DW Laser Printer
A MALFUNCTION WAS DETECTED - CODE C0500
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Minolta Di3510 All-In-One Laser Printer
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Oct 14, 2009 | HP DeskJet 722c InkJet Printer
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Bizhub 600 Malfunction Detected C-2807.
You need a service guy to stop by. Resetting the machine is a temporary solution only. Service will be able to print reports and see where the issue lies if it goes beyond just fixing a part.
Dec 29, 2007 | Konica Minolta bizhub C351 All-In-One...
61 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
