Question about Dishwashers
I have a HOTPOINT dishwasher which is about 5 years old and recently when the rense/drying cycle is finish, water is left behind in the dishwasher. The dishwasher is level
  • 12,061 Answers
Http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
http://www.repairclinic.com/Dishwasher-Repair-Help
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_INDEX_DW
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
Please find above troubleshooting and repair sites as well as service and repair manuals, most dishwashers are more or less the same and all respond to the troubleshooting. Please use these to help you troubleshoot and repair your dishwasher.
Posted on May 09, 2010
Kitchenaid KUDS02FRSS0 dishwasher. Stops mid-cycle, sometimes wash, sometimes rinse, sometimes dry. Must restart 4-5-6 times to get it to finish. When finally done dishes are clean, hot & dry....
Hi Dennis.
If the dishwasher is hanging on in the middle of the cycle it is usually the heating system. If the temperature of the water is going up after filling, then the element may be working. The element is tested using a multi meter set on Ohms to read impedance across the heater element contacts. If impedance is infinity (open-off limit), then the element is gone. If the element is OK, then the bi-metal thermostat or the fuse must be replaced. The heating assembly is located at the base of the appliance, behind the kick panel.
Behind the kick panel you should also find the tech sheet illustrating how to run the diagnostic cycle for this model. Run a diagnostic cycle to confirm that the problem is with the heating system. Drain, water sensor and inlet problems sometimes may also result in cycle not finishing.
You can find parts and diagrams for your dishwasher in this page.
Regards.
Ginko
Dec 08, 2011 | Dishwashers
Can you explain why after 5 years of excellent operation, recently we retain water in the bottom of our dishwasher after the regular wash cycle has finished Thanks
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 18, 2010 | Bosch Dishwashers
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Detergent remains after wash cycle
You should start using Electrol liguid dishwasher deterget, which comes in a container that dissolves when ittouches water. i've been using it for about a year, and it doesn't leave anything and my dishes look better than ever!
Apr 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Hotpoint Dishwasher 7830 Deluxe
you can change detergents i recommend eletrosol tabs they work great.Also run a mixture of vinager about 2 cups through the wash this should help
good luck
Dec 08, 2007 | Dishwashers
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher stops inbetween rinse and dry
hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Jun 15, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
