Question about Jensen TS2050J 20" TV
The picture is smashed down to a narrow horizontal line
Still has sound but the picture is only a horizontal line extending all of the way across the screen
  • 70 Answers
Check solder on the vertical output or change it. Dont know # but look for IC screew on heat sink with about 7 to 14 pins.
Posted on Apr 28, 2010
My 27" ( aprx 6 yrs old)Tv first had only a horizontal line across the screen about 1/2" wide, good sound but no picture, now it only clicks like its turning on and off when you plug the tv in, no pictue...
It has gone into a self protect mode where it will shut down because you have a fault in the frame stage of the TV (horizontal line). This will most likely be a failure of the frame output IC. Replace this & you should restore the normal picture.
Oct 11, 2009 | Sylvania Televison & Video
Turned on, and picture went out(just a line)with sound. never had problem with picture,but remote stop working about a year ago, cable tech said its tv not the remote
If it's a horizontal line across the face of the picture tube, your TV has a problem with its vertical output. Most likely, it's bad solder connections to the vertical output IC. Because this part gets very hot during normal operation, the connections to the circuit board can crack and the part quits working. All you see then is that narrow line across the tube. A few minutes with a soldering iron to repair the connections is usually all that's needed to fix the TV. It's also possible the part has truly failed, but the bad connections a much more common. A service shop could do the repair if you don't know anyone with the soldering skills.
Mar 29, 2009 | Panasonic CT-25G6 25" TV
No picture, only a horizontal line across the screen
Hi and welcome to FixYa,
Your described problem indicates failure at the vertical deflection circuitry. Almost always, this would be a defective vertical IC. In some instances, this could also be caused by the absence of Vcc (supply voltage) to the said IC. This is a relatively easy/quick repair. What would be more challenging is identifying the IC, removing it, and replacing. Replacement would be readily available from most electronics part stores including Radio Shack.
Good luck and thank you for using FixYa.
Feb 24, 2009 | Zenith Televison & Video
Line on the Picture Screen
panel t-con parts n/a will most likley be replaced.
Nov 03, 2008 | Protron PLTV-32 Television
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Jensen TS2050J 20" TV Logo
243 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
