Question about Honda Pressure Washer PSI 3000
Champion 1750 washer
Cuts out after 10minutes, if I leave it for a couple of minutes it is OK to use? Bit annoying more than anything
Manual for champion cpw 1750 pressure washer
Go to manufacture web site and search model for download.
Oct 03, 2014 | Champion International Garden
Zafira 1.6 petrol 4 injectors open when hot
I woud suspect if it is all 4 it is an open circuit in the wireing. When faulting & won't go follow the injector wireing back from the injectors & slightly bend the wireing harness while someone is cranking the vehicle. Pay particular attention to where the harness runs near the exhaust (if it does) & check for any melted parts of the loom or conecting plugs. Also disconnect the loom at the 1st place along the loom & look at the connector for anything unusual.
Jul 01, 2012 | 2006 Opel Zafira 1.6
Runs for a couple of minutes then cuts out
The guy above is spot on try what he says .
Mar 02, 2012 | Pitco Frialator 35CS Deep Fryer
Ford probe 24v sport engine, starts ok cold, but after a few minutes warming up it cuts out, leave it for a few minutes and it starts and runs no problems, just the cutting out bit thats a problem
Hi and welcome to FixYa!
Mostly this is caused by a failing coil pack. It is located on the side of the engine where the spark plug wires are attached. You will need to remove the cap to gain access to the coil pack. Once replaced you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 27, 2011 | Ford Probe Cars & Trucks
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
Unit will start and run normally, but cuts off after 10minutes
Was it new 10 months ago? If so, it is still under warranty. Contact MaytronicsUS at http://www.maytronicsus.com/en-US/home/homepage/ and request warranty service.
Jun 09, 2009 | Smart Pool Inc Dolphin Diagnostic...
Washing machine makes a loud rattling sound
Hi.k.
Even though you have cleaned filter, there could still be something in the pump, you need to remove the pump and check there is nothing in it.
Hope this helps.
Good luck.
Please leave feedback
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Honda Pressure Washer PSI 3000 Logo
119 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
