Question about Cannon Chesterfield C60G Kitchen Range
Zanussi oven igniton keeps sparking
When I light the main oven on my Zanussi the ignition starts sparking after about 5 minutes and will not stop until the oven is turned off.
What do you think is wrong. I have checked all the wires and fuses but it still happens, any suggestions??
Thanks
Tracey
5 Suggested Answers
  • 23 Answers
SOURCE: oven wont light no gas
Check for any sort of breaker that might have tripped. There could be a safety shutoff that will prevent the gas if ignitor won't work.
Posted on Dec 08, 2007
SOURCE: Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Posted on Oct 14, 2009
heatman101
  • 43501 Answers
SOURCE: Premier 20" range with electronic ignition - the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 08, 2010
KevinWhite
  • 1902 Answers
SOURCE: hi, i have a kitchenaid
Hello & Welcome to FixYa
Please check this parts image, you will have to test the oven temperature sensor(part#29) and door latch(part#22) before replacing the electronic control(part#33). You can test the temperature sensor first, if it reads between 1080-1120 ohms then it is fine and the electronic control needs replacement. It cannot be the spark module as the stove top works fine and it cannot be the main board as oven and stove top are fine. Please get back to me if you have any other questions.
Kevin
Posted on May 10, 2011
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Troy bilt troubleshooting
-Try replace spark plug first. If still do that then the ignition coil is bad when it's hot.
Good luck
mai
Aug 28, 2014 | Garden
Zanussi gas cooker gas not coming through no ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jul 30, 2014 | Zanussi Ovens
How long should an igniter last on a gas cooker
depends if its a batteie or mains if battrie change when it stop working if its mains any time its light a light bulb and they cant be fixed you have to replace it 4-5 years some times but new cookers dont last long at all 2 years some times ok
Oct 17, 2012 | Zanussi Ovens
I have a vikin 30 inch gas stove it been a problem for the last two years i had a repair man here four times. The problem is the oven will not light and when it does and then meets the desired temp and...
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Jul 08, 2011 | Viking VGSC366-6B Gas Kitchen Range
My gas burners do not light for up to 5 minutes. I always get a spark on every burner from the automatic pilot when I turn it to light but it can take from 1 second to 5 minutes to light.
The ignition spark needs to jump from the electrode tip to a piece of bare metal on the burner. Make sure the burner area is clean and dry.
Nov 01, 2010 | Electrolux Microwave Ovens
I have a 36'' Wolf LP oven with 4 burners and a charbroiler in the center, When lighting the charbroiler, the electronic igniter continues clicking up to 5 minutes after the charbroiler lights
Hi.
The igniters are all controlled by a main hub switch located under the cooktop panel.
Replace the sparking igniters module to fix the sticky igniters problem.
Regards.
Ginko.
Mar 03, 2010 | Stoves Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Cannon Chesterfield C60G Kitchen Range Logo
324 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
