Question about Lexmark X1290 All-In-One InkJet Printer
Power failure Having stored the printer for 4 months, when switched on, no power. Tested cable & fuse - no problem but cannot detect any voltage output from transformer pack.
    Genius:
  • 1,087 Answers
Unplug the power supply(the black box behind the printer where the power cord is attached) from the printer. With the power cord plugged in to a known working power outlet in the wall and the other end securely plugged in to the power supply, check for voltage output. If still none, Lexmark may be able to send you a new power supply for free. You can contact Lexmark at 1-800-LEXMARK(1-800-539-6275).
Posted on Apr 28, 2010
Testimonial: "Thanks - have done what you suggested."
No start no power to ignition coil tested high current fuse panel no power there either 1994 ford Taurus 3.8 fuel injected
Ignition switch supply's B+ voltage to ignition coil fuse in the engine compartment fuse box , 10 amp fuse . If no B+ voltage there check ignition switch .
Dec 16, 2015 | Ford Cars & Trucks
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Why will my zd21 kubota zero turn mower pto clutch not engage
First check fuse. Then with a volt meter check for voltage on the 2 wires going to the PTO clutch with the key and pto switches on but motor off ( you may need to trigger the seat switch as well). IF voltage is detected the clutch its self is suspect. If no voltage then check for power into the PTO switch and then out of. If power in but not out then the PTO switch is suspect. And keep chasing voltage down the line until you find the failure. Voltage travels from key switch thru fuse, PTO, seat, and reverse switches to the clutch
Sep 01, 2014 | Garden
No power to 2000 F 250 7.3 diesel after changing positive battery cables
Did you check both the positive and negative battery cables? The two fuses on the right are voltage for ignition switch. Use a test light, see if the fuse circuits are hot? Should be hot all the time. There are fusible links involved, also. The battery junction box is under the hood.
May 21, 2017 | Cars & Trucks
Hi, I have a Yamaha RX-A700, It has a flashing power led on the front (stand-by), but i'm not able to switch on the main power or do nothing
Hi.
The receiver is in forced standby because an internal error has been detected. The condition occurs when there is an internal failure, a wiring related problem (e.g. bad cable), or a wrong voltage from power source is detected (e.g. power surge).
At user level troubleshooting consists in disconnecting power cord, waiting ten or twenty minutes and connecting back (power reset), or in checking cables connected to the unit, replacing cables and restarting the receiver with no cable connected.
If that does not help, then there is an internal failure.
In that case contact Yamaha at the number listed in the owners manual.
Regards.
Ginko.
Mar 08, 2011 | Yamaha RXA700 Receiver
HP LaserJetIIIP - just won't switch on - cable and fuse OK
I can't believe that someone is still using one of the first LaserJet printers I got certified on!!! If you really want to gut the machine, there is a fuse in the power supply that could have blown. It is also possible that the power supply has finally died on its own after all of these years. You may just want to check the output voltages first to make sure of the status. If some voltages are present and not others, the fuse is still good, but the output circuitry is shot, in which case you would need to get a replacement power supply (if they are even available anymore).
Be careful with the disassembly process. The plastic clips may be brittle after almost 2 decades and could easily snap apart.
May 29, 2009 | HP LaserJet IIIp Printer
1997 Satrun SL 2 alternator failures
Miserable engineering.
My '95 SL2 purchased new, ate 6 (SIX) alternators, that fantastic "27 patents" automatic transmission, two sets of front disks and finally dropped a rod cap at 56,700 miles of very civilized driving.
I 'sold' it to my youngest son for $1 as a hobby when he got bored with his Jeeps or to donate it to a fund-raising bashing contest.
Now, the reason the alternators die -
They are buried in the engine compartment and get hardly any natural cooling there and, I don't know what kind of stupid engineers GM employs these days, but that alternator at 105 amps rating must deliver up to 1200 watts of 12 volt power an d it is too small to effectively dissipate the 1200 watts of sheer heat it produces while doing it.
If you have any appliance that absorbs 1200 watts (10 amps at 120 VAC), just check to see how much heat that is and even if spread over a larger area and bulk of the alternator, you think that would be a good environment for the semiconductors that are used to make the DC and regulate it.
It's a absolutely insane design and convinced me to never, EVER buy another anything from GM!
Sorry to vent but it still irks me after over 4 years of trouble-free Subaru ownership.
I wish you luck.
Aug 06, 2008 | 1997 Saturn SL
40amp fuse blows
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down or blows the fuse when you apply remote voltage (turn the head unit on), the amp likely has blown output transistors.
Nov 24, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Kenwood excelon kacx401m
Sounds like an overload, amp switches on, can't get enough juice and switches off. Get a friend with a volt meter to measure the voltage at the amp power terminal as you turn it on, if it drops below 10.5v the amp hasn't got enough juice. Some amps can cut out before the fuse blows, so you never know it's an overload. I'm not sure what you mean by a 'power slide door'
Apr 20, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Lexmark X1290 All-In-One InkJet Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
