If you formatted the card hopefully the pics were not on the phone if so they are all deleted but if they are on the phone look into your phones' gallery and media center.
Hi, first, your Motorola razor V3mobile phone, has blue tooth and mp3 player facility to recieve and play song which is good. All motorola razor V3 phone has the capacity to receive song into the phone, but does not have the capacity to with hold much songs.Why?
Because all Motorola razor V3 phone does not have and external memory slot to accommodate more extra song on the phone, But it has an internal in-built memory to store data in the phone.
The input memory has the capacity to store data,like music, videos,pictures and so on, But the memory which is the "internal memory" of the phone only has a limited amount of data it can carry in it.
So that's why you can not put in too much data inside the Motorola razor V3 phones.
You can also put more some more music inside the phone by managing the internal memory of the phone by using a converter to convert the music files into smaller bit rate.
Normally music bit rate is always 128kb,but you can reduce it by converting it to small sizes of bit rate precisely 64kb or 32kb.
Warning!!, when you reduce the bit rate of a music,it might not have the same quality of sound it has before you converted it into a smaller bit rate.
You probably need to convert the songs to mp3 format to play on your phone. What model phone and what music format are the songs (what are the last 3 letters of the song name, the file extension?)
As far as downloading songs with the internet, yes, VCast is your only choice for Verizon.
However, you are free to sideload your .mp3 formatted files from your computer to your phone via a microSD card, or data cable, no matter where they came from.
If you're going to use a memory card, you'll need to insert it into the phone and format it (its under Menu > Settings > Memory usually). Then make sure that you only load the files into the music folder for them to work.
Play music files - LG enV: At the main screen, press OK to select Menu. Select Get It Now, then press OK. Select Music & Tones, then press OK. Select My Music, then press OK. Select Songs, then press OK. Select the desired song, then press OK to select Play.
Before you put your songs and file on your memory card did you first insert the memory card into your phone, and then formatted it?
I have the LG Rumor as well and i haven't figured out a way to make the songs available as a ring tone yet, it only gives me the option of downloading new ringtones, and I can only play my music in the music player ='(
When you put the pictures onto the card form your pc you have to put them into the folders created by your cellphone for example pictures to pix or pictures and music to my music on the card. How is your music formatted the razr will only read mp3 songs?
Unfortunatly store reps have mostly only one thing in mind and that is to sell, sell, sell. Itunes uses a protect format called aac. which is unable to be played unless it is converted, the samsung alias (aka u740) does play MP3 format. My suggestion to you would be to use a program called Daniusoft Media Converter, to convert the music you have to mp3 and then transfer them to your phone via memory card or Verizons Music Essentials kit.
get motorola phone tools. MPT is free in all kinds of places online, and you can put about 30MB of music on a stock v3c(though, it limits your text and sms space.
