Question about Belkin (F5D5231-4) Router
When am using me wireless belkin router the modem and internet icons on my router, the lights turn orenge. why is this because i cant connect to the internet?
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Apr 28, 2010
Blinking amber in my Belkin N + no internet connection
If Your Belkin Router Did Not Work Just Reset Your Belkin Router Using The Reset Key and Setup Your Router Again[Don't Worry its Easy and Simple And I Will Guide You How to Setup The Belkin Router. Belkin Support And Belkin Router Troubleshooting Guides TechVaidya Let's Learn How to Reset Belkin Wireless Router To Default Setting -
  • Press the Reset Key Using a Pen At The Back Of Your Router And Hold For 30 seconds.
  • Restart Your Router And Modem And Good Job For More steps Visit How To Reset Belkin Wireless Router To Default Settings?
  • Your Belkin Router Has Been Reset And Now You Can Setup Your Belkin Router in Simple Steps just Follow This Step By Step Guide To Configure and Install Your Belkin Wireless Router Please Visit How to Setup and Configure Belkin Wireless router?
Nov 05, 2011 | Belkin (F5D8235-4) Wireless Router
I cant connect to the internet
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
I have a Belkin 8623-4 and the "wireless" and modem icon flash orange. The internet icon does not light. Solve this
Are you using dsl or cablemodem?
If the internet led does not come on, then your router is not getting any communication from your dsl or cable modem. try reseating the connections and reboot each device.
Sep 20, 2009 | Belkin (F5D8231-4) Wireless Router...
Blinking amber light on modem icon
that means there is usually a problem with your modem. you know how to hook up a router, right? usually you unplug power from both devices, plug in your modem and let it load, then plug in your router. (with some isp's id will work the other way around.
May 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cant connect wired to my router modem? it works via wireless
Do you know for sure that:
A) The cable you are using is correct? Have you used it elsewhere?
B) Is the network connection enabled? Goto Start, Network Connections and look at the status of the connection. It may just be disabled or miss-configured.
Apr 09, 2009 | Belkin (F5D7230-4) Router (587009)
When my Belkin N Wireless Router is turned on all
hi try this
  1. Unplug the power cable from the modem.
  2. Open a Web Browser
  3. In the address bar type http://192.168.2.1
  4. Click on Connection Type in the left hand column under Internet WAN heading
  5. Enter your password if any and click Submit
  6. Click on Dynamic and then click on Next
  7. Type in your Hostname if required.
  8. Click on Apply Changes
  9. Plug the power cable back into the cable modem.
  10. Click on the Home link at the top of the screen
  11. It should now show Connected under the Internet Status column
Mar 03, 2009 | Belkin (F5D7231-4) Wireless Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
69 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
