Question about Sony STR-DE325 Receiver
I can not turn on the receiver with the remote control, turning it off works. What can I do? Please Thank you in advance,
  • 1 more comment
  • gogoplata13 Apr 28, 2010
    Dear Larry,
    The probem is fixed, thank you very much.
    best regards,
    Plata
    Dear Larry,
    best regards,
    Plata
  • Larry Stiles
    Larry Stiles May 11, 2010
    please clarify question. I think theres a type-o
    Champion:
  • 287 Answers
Must have a bad remote control then . Did something spill onto the remote near the power on button? Short of getting a new remote you could try poping thr remote control apart and cleaning it out with a mild detergent. Larry's Electronics
Posted on Apr 28, 2010
3 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: the receiver is turning itself off - i.e back to standby.
If you don't use the remote control is it okay? If so, tear apart your remote control, use a Q-tip to clean all the lines in the circuit board where the rubber contacts touch. Then make sure that the rubber buttons don't have any 'gunk' on them that are making them stick. Clean the rubber pad with a qtip with dishsoap. Dry well, put back together and see if she works. Report back on your success. Good luck.
Posted on Dec 29, 2009
SOURCE: Greetings. I have a
Hi xekes123, I had the same issue as you have described. It started working once I set one the knobs at the bottom of the remote to "Audio" and the other to "CD-R/MD". I made sure at the back of the remote MAIN is "ON" and then pressed "System" button (at the back)....to just verify its working. Hope this might help you.
Posted on Feb 19, 2011
Testimonial: "The solution of rameshbaboo worked forDenon remote RC1046. I am amazed after trying so many other different things. I cannot thank you enough."
Yamaha RX-V359 the remote sensor in in the unit is not working. I have tried the remote control on another machine and that works
If the remote is working, but not with your receiver, there is maybe ID mismatch. Both the remote and receiver can be set to either ID1 or ID2 - this is used when you have 2 receivers nearby, so that both of them don't react on commands from both remotes.
See the "Advanced setup" of your manual. On receiver you can check/change the ID code by powering the receiver on (press STANDBY/ON) while holding down the STRAIGHT button on front panel. Display will show "Advanced setup". Use "program < >" keys to navigate the menu until you got to "REMOTE ID-XYZ". Then press STRAIGHT to select ID1 or ID2. Now press STANDBY/ON to turn the receiver off. After turning it on again, it will use the new settings.
You can also try to reset the remote control codes to factory defaults. On remote, press CODE SET with a tip of a pen or pencil. TRANSMIT light on remote will blink twice. Now press SETUP on the remote and then "9981". TRANSMIT should now blink twice and remote control is set to factory default codes.
Oct 12, 2014 | Yamaha Audio Players & Recorders
Remote rc 1030
it must be your remote has been broken (just like my remote on tv) better to buy a new remote or buy a universal remote control.
thank you for using fixya
CHARCOIS
Oct 31, 2008 | Denon AVR-2807 Receiver
Ceiling Fan Lights won't stay on
Try changing the frequency on the receiver & transmitter.
Nov 24, 2013 | Dryers
Greetings. I have a Denon remote RC - 1046 that does not seem to operate lately. I thought it might be the sensor on the receiver but the remote is able to turn the receiver on and off so I would think...
Nov 19, 2010 | Audio Players & Recorders
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
Hi -- I have a Logitech Harmony 676.We installed a new component ( a Bluray player ), and had to create a new account. So we went through all the steps, and now we can't get any sound. Also, the TV doesn't...
First you need to figure out why your not getting sound. For the following don't use the remote. Turn everything on manually. Set the TV's input to the source you want i.e. DVD, input1, inuput2, etc... While viewing that source manually turn up the volume on the TV or receiver. If using the receiver, toggle thru the inputs untill you here your program. Write down the combination of equipment and there input settings. Bottom line we need to get your hardware working and understand the settings before we start working on the remote. Once the hardware is working you can then program the Harmony with the correct settings. If your hardware is not getting you audio please send me more information concerning your setup. TV type, Cable box, direcTV Reciver. I need to understand your setup before I can help you troubleshoot your system.
Hope this helps.
Jan 27, 2010 | Logitech Harmony One Advanced Universal...
The receiver is turning itself off - i.e back to standby.
Dec 29, 2009 | Marantz SR-7200 Receiver
I have Sony Universal remote that I cann't sync or learn commands
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 09, 2009 | Sony 8-Device Universal Learning Remote
Remote code to turn akai TV/DVD combo on/off
Hi hojha, Here is the instructions from Dish Network. Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
Let me know if this helps and please rate this solution. lone99star
Jan 13, 2009 | Akai LCT3201TD 32 in. LCD Television
Receiver just blinks standby will not power on
I have been so bummed, days now I have tried to get my Pioneer receiver to power on from standby with no luck.  We now have our receiver back, the same solution worked for us. Be sure to push the buttons on the receiver unit not the remote.  Thank You! Thank You!
Jan 30, 2007 | Pioneer VSX-D812 Receiver
Sony STR-DE325 Receiver Logo
164 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
