Question about Samsung SyncMaster 226CW 22" Monitor
SyncMaster 226BW is stuck in standby or at least it shows the signs of being in standby (blinking power button / no display). This happened over night, and a simple restart doesn't seem to fix the issue.
  • 11,361 Answers
Try it on another PC first, check VGA cable, but more likely to be the monitor for monitor this old.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 28, 2010
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
I have a Samsung Syncmaster 710M that's about 5 years old. It had been lying around in its box for more than a year. When I tried to use it recently it shows the "Check Cable Signal" screen...
when you connect your lcd with computer and when you put on your computer after that press the source button on your lcd, then it will bring the display in front of you dear. thx
Jun 24, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
I have a samsumg 226bw that is acting up. When I turn on my computer, the monitor blinks once to show that the computer is booting, then after that no display. If I turn monitor off and on again, the...
You could have a faulty inverter board or faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 27, 2009 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Nov 20, 2008 | Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Blinking or wavery screen
1. cheak display cable in blinking position.
2. Voltage problem. main capacitor 220mf / 420v .
3. ptc problem.
4. cheak out put capacitors
5 electrical distabence.
Oct 01, 2008 | Computers & Internet
Samsung SyncMaster 226CW 22" Monitor Logo
1,032 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
