Question about RIM BlackBerry Curve 8310 Smartphone
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from
Blackberry server which wont void your warranty, & generate code
based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work
with single network, you can use your Blackberry in any part of world
with any
network
including your browser & MMS picture messaging to work, yes with
just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
Posted on May 11, 2010
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry 8310 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry 8310 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Posted on Oct 14, 2011
Posted on May 14, 2010
Blackberry Unlock Codes are usually use to unlock bb cell phones. If you want to unlock your blackberry 8310 you can easily get your blackberry 8310 unlock code from here http://blackberryimeiunlockcode.net or ry search a better one if you think so
Posted on Jun 04, 2012
Hi
u can get blackberry 8310 unlock code from this web http://blackberryimeiunlockcode.com
it can provide u code + following instruction for applying code on your mobile& also in cheapest price after this u will be able to use any sim card onyour phone in any region of the world
thanks
Posted on Oct 07, 2011
Hello.
You can get MEP Code for your Blackberry byBlackberry unlock code provider.
mep code is generates by blackberry server.mep generate on thebasis of imei # ,the imei # have 15 digits and unique for every single phoneand its mep code is also unique.
dont try fake code blackberry has 10 attempt tounlock code.if you missed your 10 attempts.your blackberry locked forever.
this official black berry provider will helps you a lot forunlocking and other kind of problemssssss
Posted on Jun 22, 2010
SOURCE: blackberry 8310 no service
First, please download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 15, 2010
SOURCE: uk unlocked blackberry 8310. call failed
Are you sure your phone is unlock properly ?
check the status of your set & also call orange for Vendor ID.
This site will help you a lot in every thing
http://www.blackberryimeiunlockcodes.com
Posted on Feb 18, 2010
SOURCE: what is the network MEP code for att?
unlock your Blackberry CURVE eaisly with Blackberry Imei Unlock code. first call your service provider ask your Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry MEP Codes. Buy your unlock code from third party. i hope this information is help you :)Good Luck
Posted on Oct 13, 2011
Warning : Do not enter
any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Blackberry
Curve 8310 mobile phone, your phone may get hard locked and sometimes
become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
May 20, 2012 | RIM BlackBerry Curve 8310 Smartphone
Jun 01, 2011 | RIM BlackBerry Curve 8310 Smartphone
Oct 24, 2010 | RIM BlackBerry Curve 8310 Smartphone
Jul 28, 2010 | AT&T Blackberry Curve 8300 Smartphone
Oct 01, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Sep 28, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Aug 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
Nov 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
May 16, 2008 | AT&T Blackberry Curve 8300 Smartphone
161 people viewed this question
