Question about Pitco Frialator SG14 Deep Fryer
I have a gas fryer (pitco) that has no electric running to it,why does it have wires running from the thermocoupling
  • Pitco Frialator Expert
  • 683 Answers
The thermopile on gas operated equipment acts as small voltage generator when heated that energizes the pilot valve and main valve of the gas valve,. Without it, you will not be able to fire up your fryer.
Posted on Jun 06, 2011
My pitco fryer SFSG18 will not light it has spark but does not seem to be getting gas when trying to light
Have you tried inspecting/replacing the thermocouple? This is the thing you heat when initially lighting the pilot.
You may also have a stuck pressure valve, but that is unusual.
Apr 02, 2016 | Pitco Frialator SG18S Deep Fryer
Are there any electrical connection to fryer
if it is gas,no,,if it wont light,then the thermocouple is bad
Apr 23, 2015 | Pitco Frialator 35CD Deep Fryer
Pitco fryer pilot light wont stay lite
The thermocouple is bad or the pilot light is not adjusted to heat the thermocouple to the point where the safety shut off stays on.
Jul 09, 2014 | Pitco Frialator 35CS Deep Fryer
How can you tell if the pitco fryer safety switch is bad
The safety switch is operated by extremely high temperatures. If the safety switch is bad, it will not shut off at extremely high temperatures.
Jun 02, 2014 | Imperial IFS40 Deep Fryer
Is ther a special thermocouple for the friolator
There are different thermocouples for different type of gas valve. You can order the thermocouple for your pitco fryer at www.middleby.com and look for the local service/ sales office in your at pitco website there.
May 24, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco frialator and the pilot will light but when button is released after heating thermocouple, it just goes out. I've replaced the thermocouple but still the same. The pilot flame is in the...
Check if the unit receives the right amount of fuel as stated on its nameplate, if it does, check all wires for loose connections, Milli volt wont pass on loose wiring. If this does not correct the problem, you have to replace the gas valve, the main valve coil may be shorted that's why the pilot is shut when main valve is energized.
Apr 30, 2011 | Pitco Frialator 35CS Deep Fryer
Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Wiring diagrammed of Pitco model 7-2wkss
Sorry to break this to you but all pitco fryer model numbers start with an S, please make sure what manufacture this fryer is made by.
Thank You
Jul 12, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco fryer pilot out
if you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Jun 19, 2008 | Pitco Frialator 35CD Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
