Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Channels are not available on phillips tv
I have standard cable when I put the cable into the back of the tv and turn it on I cannot change the channel it says "channel not available"
  • ttaranova May 03, 2008
    phillips tv (25ST220L/17) will not allow me to go higher than a certain number of channels either. Read something in the online manual (tv was given to me, no remote control, either) that said you can change it from commercial setup to consumer, but you must have one of their remotes to do so? Any way around this?
    Thanks
    Genius:
  • 1,913 Answers
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Posted on Mar 24, 2008
    Guru:
  • 194 Answers
This can be that the tv is not set up to "cable" in the menu. it may be on "antenna" so you would need to switch this to cable. another problem is that you may have to get a converter box for each unit. Comcast has a converter box that you have to get to make the channels show up now that the digital over the air boxes are out. if using the said box you have to have the tv on channel 3 or 4.
http://www.comcast.com/Media/1-2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Nov 15, 2011
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
MORE channels! for CHANNEL SET UP PHILLIPS pl9127 c101/ 27f 800 7583
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Oct 28, 2008 | Philips TS2746C TV
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
Channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Apr 17, 2008 | RCA F27442 27" TV
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips tv
Walter,
Turn the unit off and unplug it for about 15 minutes. Then pulg it back in - power it up using the power button on the front of the unit then try changing channels, volume, ets with the remotes.
Bill
Nov 27, 2007 | Televison & Video
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Aug 04, 2007 | Philips 25PS40S 25" TV
Guide plus+ gold
use the editor in the guide to turn off and on and correct channel numbers. that should do it..!!
Apr 13, 2007 | RCA G36705 36" TV
Televison & Video Logo
835 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
