Question about Kenmore 22422 Top Load Washer
My washer won't spin out or drain water from the tub, it will fill up and agatate. So do I need to call a repair man or can I fix it myself. Thanks
    Problem Solver:
  • 18 Answers
Check to see if the filter has been cleaned. Possibly it is blocked and that is why it is not draining.
Posted on Apr 28, 2010
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Water not draining my ge washer will ot drain the water. it is spinning but not draining. i took out all the clothes and set it to spin and drain but it wont drain the water. what to do? can i do it...
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Asko 6221 washer won't drain, now won't fill either
How long did it work for after the repair man replaced the drain pump?
Thanks,
Lee
Jun 17, 2008 | Asko W6221 Front Load Washer
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer drains but then continues to fill with water.
There is a small piece that is inside where the water runs into the machine it is called a water inlet valve. I had the same problem a few months ago. I know the part is not that expensive but the labor was. When the repair man left I looked at the part and thought I should have tried to fix it myself. It was only a couple of screws.
Hope this helps.
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont drain water
It won't drain If your washer won't drain, check these:
It doesn't spin or pump
It pumps, but the water returns
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22422 Top Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
