Question about Baumatic B187 Stainless Steel Electric Single Oven
My Baumatic oven door is locked shut,and wont open,have tried switching power off ,resetting timer,can you help with any suggestions apart from a 12lbs sledge.
3 Suggested Answers
SOURCE: Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Posted on Jul 27, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
My whirlpool RBD305PRS00 double oven wont heat up and is locked
The door and controls lock when the oven temp is very high or when on pyrolitic cooking if that is available on your oven. If the controls wont reset or the door wont open try turning the power off for about 30 minutes and then try again. reset the clock and hopefully the oven will return to normal..
Aug 26, 2014 | Ovens
Door will not open and oven will not shut off
The door latch will open after the shut down, therefore go to the home circuit breakers and shut off the power to the oven. Wait a few minutes and try to open the door. If still locked, reset the power to the on position and see if the oven rest and shut down properly and the door lock released.
Dec 31, 2013 | Kenmore Ovens
No power, door locked
there are 2 thermal switches within the component area in front of the fan of the oven, they open and close like a switch at certain temps,if one of these go bad (stays open after oven clean cycle)and oven cools then it wont let power back to the unlock motor,you can access these switches and bypass them to test them,if lock works then merely replace that particular switch
Feb 04, 2013 | GE Ovens
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 | Ovens
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Cleaning error E1 F5
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2009 | Baumatic B187 Electric Single Oven
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Locked oven door
try turning off the circuit breaker, resetting the power sometimes trips the self clean latch to operate, youll need to push in the door light switch.(it will have to think the door is closed to operate)
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Baumatic B187 Stainless Steel Electric Single Oven Logo
57 people viewed this question
Top Baumatic Ovens Experts
ashburton
Dennis Boxerman
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
