Question about Poulan 14" Chainsaw
Problem starting need spec's on 12 year old saw for tune up and spark plug gap.
  • dontbother10
    dontbother10 May 11, 2010
    Which model? Reply below please.
    Brigadier General:
  • 4,088 Answers
Spark plug gap is: 0.020". Insulator should be a light to medium tan color. If black, then too much fuel going into the engine. Remove the flywheel side cover to expose the flywheel and ignition module. Check and set the gap between the flywheel magnets and the ignition module poles by using a thin business card for a gauge. Check the muffler, air cleaner, and fuel filter for plugging. Check the condition of the fuel lines and the primer bulb. Check the carburetor fasteners for tightness. The carburetor may need to be dis-assembled, cleaned and re-kitted. The diaphragm in the lower chamber needs to be flexible with no cracks or holes. With luck, this will get it running well again.
Posted on May 05, 2010
Spark plug gap size 01 dodge caravan 6 cylinder 3.3l
A Chiltons/Haynes repair manual that covers this vehicle make/model/year will have the information you seek. Plus a lot of other goodies. I'll give you the gap for the 3.3 V6 used in the 1984 thru 1995 (we use it for our 1998 Grand Caravan). okay per tune-up specs, that spark plug gap is, drum roll please, 0.050 inch/1.3mm. These specs are for the OEM spark plugs Champion RN14MC5. Best of luck accessing the 3 on the back side.
May 31, 2015 | Dodge Cars & Trucks
What is the spark plug gap 3.2 ltr engine
2001 really., that year? wrong year, you did that.
in the usa, (this is a usa forum)
posted 100s of times.
open hood, look up under hood, see that EPA sticker,
showing just that?
the 3.2L was introduced in 2008/9
depends on what plugs, some are not gap settable.
usa spec, 2010.
read this FSM page.
hen servicing an iridium spark plug, do not touch the center electrode. The center electrode on this type of spark plug is slender and can be damaged if a mechanical force is applied. Do not clean or adjust the gap for the iridium spark plugs.
IF NOT THAT THEN,
old technology spark plugs, not above.
The 3.2L engine spark plug air gap specification is: 0.043-0.047 inch (1.1-1.2mm).
Mar 11, 2015 | 2001 Suzuki Grand Vitara
5 an 6 cylinder misfires
Check on the VECI label under the hood, vehicle emission control information, the long rectangular label. It shows tune-up specs and spark plug gaps. And yes, halphin, the wrong gap can cause a misfire, if too far off.
Jan 07, 2013 | Cars & Trucks
I have a knock sensor and a 1 -misfire code. I recently gave my car a tune up and within a month i had a check engine light on. Can you tell me what i should check? Thanks
If you could elaborate a bit more on what was done to the car we could pinpoint the problem right away. However, typically a tune up is plugs, wires, cap, and filter. Given those four changes, I would point my finger at the plugs. Many of times spark plugs do not come pre-gapped. Meaning the distance between the metal and the electrode, white looking ceramic are not measured per spec. If you did not gap the plugs, I would recommend taking them out and adjusting the gap to spec. You can call the dealer and ask them for the recommended spec. I have attached a pic of a spark plug with an arrow indicating how the gap is measured. You will need a feeler gauge to measure the gap and adjust.rltofixya_3.jpg
Without proper gap the engine can/will misfire.
May 26, 2011 | 1995 Nissan 200SX
Changed spark plugs in my 1999 chevy blazer and it wont crank over. Gapped the plugs to specs...should I've also changed the wires, cap & rotor also?
When you go to an auto store and they give sell you spark plugs they should already be gapped to spec. There is no need to adjust the gap. This may be the reason your car will not start. I would try new spark plugs first then wires. Since the vehicle is a 99 it probably could use a tune up (spark plugs, wires, coils, cap, rotor, chassis lube, and transmission fluid check and flush if needed). Also make sure that the engine block ground strap is in good condition and that there is no corrosion covering the ends of the ground strap. The ground strap is typically located near the firewall and is directly attached from the engine block to the frame of the car.
Mar 11, 2011 | 1999 Chevrolet Blazer
Need to do a tune-up. what are the settings on the spark plug and on the magneto gap.
The plug gap is 0.020". Use a thin business card for the ignition module gaps--turn the flywheel so that the magnets are under the module poles, insert the card into the gaps, loosen the module screws, and allow the poles to contact the magnets. Tighten the screws, and turn the flywheel somewhat to release the card. Then turn the flywheel one full turn to make sure the gaps don't close further. With a fresh spark plug, the spark should be blue and snappy. Hope this helps!
Dec 09, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Need the total Spec Sheet for tuneup
There haven't been tune ups in 30 years ,since GM put a computer on it's vehicles. The only spec you'll see is for spark plug gap
Aug 03, 2010 | Dodge Dakota Cars & Trucks
Need to know what spark plug to buy for my 20 year old superminin Chain saw.please and thank you. brian S. Campbell. agassiz b.c. Canada.
Go to a servicing saw dealer or auto parts supplier who has the correct plug for you (and what gap to set the electrodes). Check for spark before installing the new plug. Good luck!
May 17, 2010 | Garden
Very hard to start. Will start with autostart and
Hello Sue; Has it ever been through a saw shop for tune up (at a good shop $40±, it includes some cleaning, new plug, new fuel filter, pressure/vacuum testing, carburetor adjustment, etc.)?
The coil is under the starter cover. You might check the gap with a business or index card.
Have you tried a new plug? much cheaper than a coil. Lou
Apr 06, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Poulan 14" Chainsaw Logo
152 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
