Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How do make my router secure when its states it unsecure
How do make my router secure when its states it is unsecure
  • neill2 Apr 28, 2010
    Thankyou I will try it when I come back in a fortnights time
    Dave
  • 550 Answers
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Posted on May 02, 2010
Secure your linksys router wireless or access point administration interface linksys router wireless have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the linksys router wireless or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
source:
http://www.linksysrouterwireless.com/article/Securing-your-wireless-network.php It'tell you about securing your wireless
source
Posted on May 28, 2010
  • mozartboom May 28, 2010
    Enable WPA encryption instead of WEP
    802.11's WEP (Wired Equivalency Privacy) encryption has well-known
    weaknesses that make it relatively easy for a determined user with the
    right equipment to crack the encryption and access the wireless network.
    A better way to protect your WLAN is with WPA (Wi-Fi Protected Access).
    WPA provides much better protection and is also easier to use, since
    your password characters aren't limited to 0-9 and A-F as they are with
    WEP. WPA support is built into Windows XP (with the latest Service Pack)
    and virtually all modern wireless hardware and operating systems. A
    more recent version, WPA2, is found in newer hardware and provides even
    stronger encryption, but you'll probably need to download an XP patch in
    order to use it.
    source:
    http://www.linksysrouterwireless.com/art...
    Guru:
  • 1,049 Answers
You need to setup Encryption.
SETUP WPA2 ENCRYPTION ON YOUR ROUTER:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on Security in the left-hand column under the Wireless heading.
  6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
  7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
  8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
  9. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
  10. Click the "Apply Changes" button to save the settings.
SETUP WPA2 ON YOUR LAPTOP OR PC:
Connecting to a WPA2-secured network:
  1. Select the network you want to access.
  2. Click Connect.
  3. In the dialog box that appears, type the WPA-Personal pass phrase in the Network Key and Confirm network key text boxes, then select the Connect option. The connection should be made automatically.
If you are using the Windows wireless client on a computer that has Windows XP Service Pack 2 and cannot connect to a wireless network that uses for Wi-Fi Protected Access 2 (WPA 2) security then you will need to update your Windows wireless client.
To update your wireless client please follow the instructions found here: http://support.microsoft.com/kb/917021
Posted on Apr 28, 2010
How do you unsecure a router
reset the router. reset button is on back of router usually..press and hold for at least 30 seconds or more! Repeat if not successful.
Feb 09, 2012 | Belkin Computers & Internet
I put in my password to my router but my computer still stating unsecured.
Hi, try to innovate using complicated password. A lengthy one will help and enable other security feature in your wireless setup.
Jun 21, 2011 | Linksys Wireless-G WRT54G Router
The wireless net work I was using is no longer accessible. The only network I can access is unsecure. How do I set up a new secure network with my WBR1310?
Is this "unsecure" network your own network.. i.e your d-link router?
If so you can configure your router for security.
Please use link below, read carefully to find which is your rev
Jul 11, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
Vista attempts to connect with the router "unsecured network"
Hi Friend,
If the security is enabled on your computer then on router the security has to be enabled.
Please follow the steps:
1.Open the router page (192.168.0.1)
2.Enter the username and password
3.ClickWireless settings and fill the section as mention
Name(SSID)-As per your choice
Region-As per your location
Channel-6
Mode-Auto
Security options
WEP
Security Encryption
Authentication-Automatic
Encryption strength-64bit
Security Encryption key
Key1-type a 10 digit password
Click Apply. Turn off the router for 30 seconds and turn it on again.
I hope this will resolve the issue.
Regards
Chiranjeet
May 22, 2010 | NetGear WGT624 Wireless Router
My Router works only if I do not put security password on it.
The router works only if the network is unsecured.
When you secure the wireless network , make sure that you will change the wireless network name also. Because if you change the wireless security and if you keep the same network name then your computer will try to connect to the same network name with the old unsecured settings saved on the computer.
Try to change the SSID ( network name ) and security to WPA, check if that works.
If that doesn't work then I believe you will need to upgrade the FIRMWARE of the router.
Click here for more information about the routers and the wireless network
Jan 25, 2010 | Belkin Computers & Internet
Y linskys is unsecure, how do i secure it?
need to reset a new WEP code go to their website to find out how
Aug 16, 2009 | Linksys Wireless-G Broadband Router
My electricity went off and now my connection is open but my comp
You need to reconfigure the router. The power outage probably resetted the router to it's default settings. In the default state the router doesn't have any wireless security; hence the "unsecured network" warning from your PC.
Connect your PC or a laptop with a cable to the router, surf to (http://192.168.1.1 or https://192.168.1.1 - ignoring any security warning); which is the configuration interface of the router and follow instructions in the manual.
When you have a Linksys configuration CD, you can simply run the "Easy configuration" setup after connecting your PC with a cable to the router.
Plainly put you just have to configure the router just like when you first used it.
Feb 09, 2009 | Linksys Wireless-G WRT54G Router
Secured connection is gone and all we have is Linksys unsecured
Next time try unplugging the router for 30-60 seconds then plug it back in. Should resolve minor glitches like this one.
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
My linksys says it is unsecured. how do i make it secured?
I found a link on how you can secure your wireless network. Click here. Let me know if you will still have a problem.
Sep 16, 2008 | Linksys Wireless-G Broadband Router
Username and password
hello!
1. are you referring to the router username and password or the wireless security password ?
2. what is the exact model number of your router?
3. where did you get the message to put in the username and password in an unsecure manner?
-- the default router username is admin with no password
-- the wireless security will depends on what security settings that are configured on the router
May 04, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
135 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
