Question about Blaupunkt IDC-A09 5-Disc CD Changer
5disc multiple choice cds stuck in slots how do i
5disc multiple choice cds stuck in slots how do i remove the cds please.
    Problem Solver:
  • 18 Answers
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Posted on Apr 28, 2010
Testimonial: "Thank you so much I have removed the cds now...but when SRS button pressed to play cds it is spasmatic seems as if a wire is loose somewhere. "
Remove covers (top and bottom). Exposing workings of player. If you carefully lift the unit out of casing, you'll see @ rear of unit some vertical, threaded bars. These turn and raise/lower the play system. By lowering the play system to it's lowest position this should let you pull cd through front of player.
The locking mechanism required a little 'prising' but it appeared that one of the rotor wheels (shaped like a bobbin) had come out of its place.
Posted on Feb 17, 2012
My RF 6 Disc Changer just stopped playing any CDs. Just reads E. What do I do??
is it jammed? remove the CDs, blow in some compresed air to knock out dust and try it again. if the CDs are stuck then its a whole other issue.
Sep 02, 2015 | Car Audio & Video
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
Two disks inserted at the same time and now are stuck in the player.
There are usually two options
1...try and tease the CDs out through the slot using another old CD
2..Extract  the player from the dashboard , remove the cover and take out the 2 CDs from the mechanism
Make sure you have the security code before extracting the player
Dec 03, 2009 | Panasonic Car Audio & Video
I wish to remove two stuck cds from 4500 RDS EON without damaging the fascia.I have a 2003 Zetec 1.4 Fiesta. Isee no visible means of removing the unit, though this must be possible.
Try teasing the jammed CDs  out (through the slot in the front) using an old CD or credit card.
Alternatively the player will have to be removed from the dashboard and the cover taken off in order to gain access to the jammed CDs
Select the correct radio model from this free list of Ford radio removal instructions
http://www.fitaudio.com/index.php?CategoryID=13
Nov 09, 2009 | Car Audio & Video
CDs get stuck in the slot of my mac mini---3 years old.
Ok, let's go through the options in case you have missed one. Command E, Open Finder and click eject button next too it's name, dragging the item to trash, press F12, or hitting eject on the keyboard. If none of those work make sure the drive is not just busy. Sometimes you have to wait a few seconds even after stopping the application. You can use Disk Utility in Applications/Utilities to eject a CD. Open Terminal and type drutil tray eject If that fails, in Terminal type drutil list and then look at the list and find the drive. Tyoe drutil tray eject 1 The 1 should be replace with whatever drive # you found in the list.
Aug 05, 2009 | Apple Mac mini G4 Desktop
Toyota Matrix 2005 CD stuck
More than likely, you have 2 cds stuck in one slot. What you have to do is remove the radio form the dash, and then remove the top metal panel on the radio. Plug the radio back in, and press eject. You may have to "help" one or two of the cds out of the player.
Feb 10, 2009 | 2005 Toyota Matrix
CD Stuck in CD changer
yes... remove the radio from the dash... remove the screws that hold on the top panel on... then you remove said panel... and then you get them out by pressing the eject button and pishing them out with your fingers!!!! you can also try pulling them out with tweezers... or you can take it to an audio repair place... your choice
Jun 11, 2008 | 2003 Nissan Altima
Blaupunkt IDC-A09 5-Disc CD Changer Logo
2,877 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
