Question about Kenmore Sewing Machines
The thread bunches up under the fabric
While sewing with Kenmore 12814 the top thread bunches up underneath the fabric and jams. Also machine runs rough
    Problem Solver:
  • 18 Answers
Your bobbin cotton is probably wound on too tightly
Posted on Apr 28, 2010
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
I HAVE MODEL 12312 AND CANT GET THE BOBBIN TO WORK, THE BOBBIN KEEPS GATHEREING UNDERNEATH MY WORK. ANY SUGGESTTIONS
Please check your fabric results. Is it the bobbin thread that is accumulating under the fabric, or is it really the top thread that is globbing and knotting under the fabric. Usually, thread mishaps under the fabric are the result of an issue with the top thread.
ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disks so the thread will seat properly. Use a brand new needle. Start out with the upper thread tension set midway between high & low numbers, although this can be tweaked.
If it is in fact the upper thread, then here are some suggestions:
Sewing Machine Thread Bunching Up Here Why
Troubleshooting Thread Nesting Sew Toot
Nov 29, 2016 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Why Do Get Bunched Up Thread Under My Fabric
Feb 04, 2016 | Sewing Machines
I'm using Empisal Dressmaker 270D sewing machine. My problem is. When I sew the underneath cotton is loose
Usually, if the thread is bunching or looping under the fabric, the upper tension is too loose.. But if the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
The tension is correct when both the upper and lower threads meet in the middle of the fabric.
Sep 26, 2015 | Sewing Machines
I am trying to sew velcroe on some pillows and the bobbin thread keeps bunching up underneath the fabric and making jerky sounds...heellpp!
do not use self adhesive velcro........ the glue jams the cotton.
use the plain sew on velcro.
use a largr size needle as well.
Feb 20, 2011 | Kenmore Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
The tension is off ?? bottom thread bunches
Sounds like it could be! Probably worth trying to readjust it. Are you using a fine fabric too? That can cause bunching.
Apr 05, 2010 | Kenmore 15516 Mechanical Sewing Machine
Thread jamming under fabric
bobbins in backwards
flip it over
Dec 18, 2009 | Kenmore Sewing Machines
Sewing Machine Thread Tension problems
What size needle are you using?
Dec 31, 2008 | Kenmore 15718
Sewing Machines Logo
161 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
