Question about GE WSXH208A Front Load Washer
When spin starts - sounds like drum will detach. very load and shakes the whole room.
    Problem Solver:
  • 18 Answers
You have an uneven load in the drum, for example a shoe or something heavy that should not be in the washing.
Posted on Apr 28, 2010
I have a top loading Samsung washing machine and after washing and water has drain and starts spinning I am hearing a strange whirring sound it is only happen while spin drying
maybe there is trapped residue or something in the drum,,,,u need a technician to detach the drum ,,,clean nd replace it back...
Nov 23, 2014 | Washing Machines
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
The machine makes a clunking noise and shakes all over while spinning, but spins fine and smooth if I run it empty. From seeing other answers sounds like the drum is detached from the solid mass. Do I go...
open the back and you will see 4 brackets and a band holding it balanced one of them is loose if it aint noisy with out anything in it thats good it means the band and the other brackets are fine so it must be the bracket that shook off or poss snaped whitch can be replaced at repairclinic.com
Jan 08, 2011 | Siemens WK61420GB Front Load Washer /...
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model WFW83005W05, Serial HLY1329780. It shakes the whole room when spinning, even when we put it on the lowest spin.
There are springs that hold the tub in a balanced position. If they're loose the spin cycle will shake the washer too much. The springs can be tightened with a wrench and stop this from happening.
Jan 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle shakes the whole house everytime why
check first if any of the legs are not sitting flat on ground,check the roughness of bearings by placing your hand in the drum and rotate slowly back and forth,loose balance weight could also be a cause but id say it sounds like bearings
May 07, 2009 | Washing Machines
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
GE WSXH208A Front Load Washer Logo
199 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
