Question about Electrolux Refrigerators
My Frigidaire refrigator R134A is making rumbling noise.
My Frigidaire refrigator R134A (model # FRT18LN5BWO) is making a rumbling sound. It sounds like it is coming from the ice machine, but this is turned off so not sure what it is. It sounds like a slight rumbling or squeeking sound that goes on for a few minutes, then stops for about a minute, then does it again. It is still keeping everything cool and stuff in the freezer, frozen.
Help! Thanks!
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 72 Answers
    SOURCE: refrig & freezer set to coolest but not
    is it buzzing and clicking every few minutes?
    Posted on Jun 16, 2009
    Rumble noise right front wheel
    Sounds like a wheel bearing assembly failing.
    Jan 04, 2014 | 2001 Dodge Dakota
    Have a rumbling noise in left rear wheel while driving down the road 1999LexusRX all wheel drive.sounds like a wheel bearing.
    Have the car put on a rack and have the noise listened to with a mechanics stethoscope to confirm the wheel bearing is at fault.
    Sep 04, 2012 | Lexus RX 300 Cars & Trucks
    Intermittent Refrigerator Noise
    Call them back and make them fix it right, unless you have the tools and skill to do it yourself and let them off the hook.
    Jul 09, 2017 | Refrigerators
    My side by side refrigerator is making a buzzing noise from the ice maker area every few minutes
    That sound you here is the icemaker calling for water to fill the icemaker but not water into refrig to fill icemaker. If you have no water connected to icemaker,lift up and lock arm into place to turn off icemaker,if you do have water line connected but no ice is being made need to see why water from house plumbing is not coming into the refrig.
    Aug 11, 2011 | Frigidaire Refrigerators
    My washer machine sounds like a plane taking off when it goes into a spin cycle
    Jan 16, 2010 | Frigidaire Washing Machines
    Loud rumble sound, Vent hose vibration
    That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
    Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Dryer makes rumbling sound when starting
    If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
    Mar 21, 2009 | Maytag MDE2600 Electric Dryer
    Frigidaire dryer making rumbling noise .
    I work for an Appliance Wholesale Company at
    Is the dishwasher a front loader or a top loader? That will matter!
    Give me the model number of the unit and I will tell you how to stop the "rumbling"
    Feb 16, 2009 | Frigidaire Dryers
    Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
    Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
    May 30, 2017 | Haier HSA04WNC Compact Refrigerator
    Refrigerators Logo
    104 people viewed this question
    Top Electrolux Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
