Question about Microsoft Windows Vista Home Premium Edition for PC
All my fonts appear ghost-like characters. I may have accidentally uninstall a programme associated with the fonts. Please help.
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
Cannot edit text in acrobat x pro
you need to uninstall ,format device and re-install next put your characters on the acrobat x pro file you can do it by go c drive program-file,acrobat x pro click it add file again it will work.
Jan 08, 2013 | Adobe Acrobat X Pro
How to select a text on a computetr
If by that you mean font type, go to programme start, select all programs, select accesories, select system tools and select Character map. That will give you diferent sets od fonts.
Hope this is what you meant.
Nov 03, 2010 | Computers & Internet
I want to know how to use the keyboard of toshiba when you are writing some letters for exemple é,à,........ thank u
Click Start.
Select All programmes
Select Accessories
Select System tools
Select Character map and
Select the font you require then the character you require.
If you remember the Alt+numbers code then you won't need to go to all this trouble again.
Hope this helps.
Oct 25, 2010 | Toshiba Satellite A135-S2276 Notebook
I find that I have dozens of etra fonts, namley Ariel, when I scan down the font list. Is there any way of getting rid of them. I have tried reinstalling the programme but the6 re-appear in the new...
Hello
Thank you for using
FixYa for your problem
In your windows folder you will see a font folder, remove the fonts you do not want here
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Sierra Print Artist Platinum
I am trying to remove Norton 2006 which has expired and an old version of Norton Ghost from my computer but keep encountering a problem Error 1324 (the path My Documents contains an invalid character)...
go to majorgeeks.com..they have a special uninstaller for norton, and ghost products... also if they does not work please try revo uninstaller also available at majorgeeks.com... then if that does not work which im sure it will.. use brute force uninstaller as a last resort. happy uninstall
Oct 31, 2009 | Symantec Norton Internet Security 2006...
I cant uninstall programs from the control panel... i keep getting message ghost uninstaller says installation log file can not be found
This means that a program that you may have uninstalled earlier might have removed this needed file. You can reinstall windows..if this is your platform and select the repair instead of full install inorder to place this file back in your system. Please give more information if this does not work for you. Good Luck..
Fehdi
Aug 19, 2009 | Acer Computers & Internet
How i w'ill use hindi font's in microsoft word 2007 as I don't have hindi fonts please tell me how to gain hindi font's and how to install and use them
Open Microsoft word and select Symbol in insert menu. Select font as Mangal and subset as Devanagiri. Here u find all the characters that are required to type any alphabet.
Suppose if you want to type "अपुन अच्छा लडका है" Insert the following symbols in the order. Neglect + and <> signs. I just placed it for seperation.
अ + प + ु +न <> अ + च + ् + छ + ा + ल + ड + क + ा <> ह + ै
While typing the characters, you will observe the related characters merging themselves. After typing the required message, just copy and paste the characters wherever you want. Soon after u paste the message.. u may notice blank squares appearing instead of message (in Googletalk window for example).. Dont worry.. The tweak works after you save it/send it.
Mar 30, 2009 | Microsoft Office Professional 2007 Full...
I accidentally hit something while I was typing on msn to make the green characters on the keys appear and dont know how to change it back. it only seems to be doing on msn and not on here though. can you...
Your font is green only on msn. Go into msn log on and you have to go in to options and change the font color. It was probably a short cut key stroke you hit. If not you browsers is the problem
Aug 28, 2008 | Acer Computers & Internet
Microsoft Windows Vista Home Premium Edition for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
