Question about Maytag MZD2766GES Side by Side Refrigerator
The white disk in the door for the ice/water dispensor is disengaged, how to I reinstall it? This is a Maytag side by side model MZD2766GE
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 245 Answers
Se if it closes with your finger if it dos and it looks uneven gently snap it up in place if there is ice around it pour hot water into the back of it wear the ice drops thou don't for get to put a cup in first.thats what i did after taking of the square plastic framing and sliding out the rubber thing.don't unplug the wires just lift the frame a little try this last.you shouldn't have-to touch the wires if so unplug the refrigerator.for safety.
Posted on Apr 28, 2010
My Maytag MZD2766GE dispenses water but does not make ice
check water valve, also your water line for ice maker could be frosted that happen always, but reason is bad water valve....
appliancesrepairla.com
Jul 01, 2010 | Maytag MZD2766GES Side by Side...
Ice and water
Remove the top hinge cover on the freezer door and disconnect the plug there . This removes power to the freezer door . Remove the dispensor drip pan and the 2 screws holding the dispensor cover on . Disconnect the plug from the cover . You should now see a circuit board only held on by plastic clips , a disconnect plug on the left side and on the right , 1 or 2 wire terminals . This board is what you need to replace . When getting a replacement , take your complete model number so you get the correct board .
May 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My maytag mfi2658aes and my ice and water not
Your display board has gone out on your dispensor. This is a simpe repair and we have parts for Maytag appliances.
Just give us a call with your brand andmodel number and we will be happy to get the correct part out to you asap.
We hope this solves your problem and we look forward to working with you.
Nov 03, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold Model GD25SFXHS03 exterior ice lever not working
Your problem is probably a broken plastic switch bracket . Pt # 2180226 . To access , use a butter knife between the dispensor grill and the lower portion of the dispensor cover . FIRST , remove the cover on the top freezer hinge , and disconnect the plug there . This removes all power to the door . Insert the knife about 1 " from the side , and push down and inward , to push the plastic tab of the cover , outward . Do the same for the other side . Lift upward to slip the top tabs free of the mount . Disconnect the plug to the dispensor cover , and remove the cover . The white piece with the 2 switches , probably has a short plastic stub , broken off which holds the ice dispensor switch . Looks like maybe 4 small screws , hold the switch bracket on . Transfer the switches carefully ,because you are working with plastic . When reinstalling the dispensor cover , after attaching the receptical , slip the top portion of the cover in place , and pop the bottom to latch the lower clips .
Aug 30, 2009 | Whirlpool Refrigerators
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
83 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
