Question about Olympus FE-280 Digital Camera
Probleme olympus fe 280 ecran noir objectif qui bloque
Appareil parti en afrique donc ca peut etre a cause du sable
  • 479 Answers
SOURCE: blurry pictures
Try going thru the menu and reset camera. If not then repair
Posted on Aug 20, 2008
SOURCE: unwrite protect olympus Fe 280
go to set up and reformat. This will fix the problem
John Harlow
Posted on Jun 26, 2009
  • 4090 Answers
SOURCE: OLympus FE-280
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online ++++Thanks for using FIXYA
Posted on Sep 23, 2009
t00nz
  • 4738 Answers
SOURCE: j'ai un appareil photo numerique canon powershot
Pardonnez mon français, j'utilise Google. Oui, c'est mai-être temps d'acheter une nouvelle batterie. Batteries rechargeables ne sont pas faits pour durer éternellement. Ils devraient être remplacés tous les deux ans. Si votre batterie est plus vieux, alors il est temps. Heureusement, le NB-1LH batterie est disponible à partir de sources génériques de ces journées, et est relativement bon marché si vous recherchez.
Posted on Oct 31, 2009
  • 11967 Answers
SOURCE: need to take apart an olympus fe 280 will not
Google the words...disassemble a digital camera.
Posted on Dec 08, 2009
Mon ecran reste noir meme s'il est ouvert
Hello Nicole Savard,
Tres peu de choses peut etre determinee sur vos ennuis sans votre num?ro de serie et le modele !
Avez-vous essaye de brancher un moniteur externe... ?
Sinon, vous pouvez essayer d'avoir votre technique soutien, connectez-vous A distance... et verifier votre machine pour voir ce qui peut etre determine A partir d'un emplacement distant..
I think(?)
Good luck...
Computer Parts Laptops Electronics and More Newegg com
Apr 01, 2016 | Computers & Internet
Cartouche d encre noir est boucher
Le conduit qui de l'encre doit etre la cause. prendre une seringue avec de l'alcool et injecter dans le tube. injecter et tirer sur le conduit en plusieurs fois, pour deboucher l'encre secher. Si c'est possible de retirer le printhead (magasine) qui tient les encres laisser tremper dans l'allcool pendant quelques heures et meme la nuit durant. laisser secher pendant quelques heures, et essayer ensuite. Cela devrait deloger l'encre secher.
Aug 12, 2014 | HEWLETT-PACKARD HP Brand 564 Series Photo...
Ecran reste noir , voyant N
Ce probleme peut etre lie au mauvais fonctionnement GPU, essaye de faire une Hard reset, debranche la batterie et l'adaptateur et apui 30 sec sur power, si cela ne change rien, vous devez reparez votre gpu.
Feb 08, 2014 | Lenovo ThinkPad R51
Error code 0xb814728e
Bon je fais mon feedback aussi pour ceux qui ne comprennent pas l'anglais. J'ai ouvert par inadvertance ma HP photosmart a fond, je parle pas du petit couvercle de scan, mais de la grosse ouverture la ou on met les cartouches... et MERDE ! elle voulait plus se refermer ! Surtout ne pas forcer, mais bon en general ca donne l'impression de quelque chose qui bloque, donc une personne normale ne va pas forcer. La solution (que j'ai trouvee sur ce site, merci) c'est de se procurer du WD40, ce lubrifiant bien connu, et d'en arroser les charnieres. En manipulant doucement votre imprimante, vous allez voir, elle va se refermer gentiment au bout de dix minutes. Quel soulagement !
Aug 29, 2013 | HP Photosmart 3310 Printer
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Non syncronization mechanism CD player
1$$$
Dans l'ensemble, ça marche super : fm, am, cassette(un peut dure mais ça devait être la tension de la bande...), Auxiliaire (oc : RCI...), mécanismes de montée/descente, ouverture des tirroirs, séléction du tirroir à faire marcher... test d'allaitement de la lentille : tout ça c'est bon/.
Mais, le CD ne tourne pas!!!
Est-ce le moteur qui serait grippé? Il ne semble pas puisque, alimenté directement avec une AC/DC en 3-5V : Il toune! Est-ce le programme contenu dans ces étrange blocs noirs à bras multiples qui donne l'impression d'être des microprocesseurs(2000 ans d'avance sur Intel...) qui nécessiteraient un reset ; car, en effet, n'ayant plus la télécommande, il n'est pas possible de remettre à l'heure la pendule et par conséquent de bénéficier de tous les avantages situés somewhere à l'azimut (du sud, sens direct) PI - 7/.
Qu'en pensez-tu?
2$$$
Mar 02, 2009 | Sharp Audio Players & Recorders
Un ecran blanc au demarrage
Il vous aidera plus si vous écrivez le problème aussi en anglais. Pourquoi limiter le rayon de gens qui peuvent vous aider à seulement ceux qui parlent français? (Québec et la France). En anglais c'est presque tout le monde!
Jul 11, 2008 | Acer AL1916W 19" LCD Monitor
Unable to close Lid
Sounds like the hing on back is broken. Look on the back of the cover, there will be 2 hinges holding the scanner on. Probably a piece of plactic broke and is hanging up one of the hinges.
Possibly a small spring.
Feb 28, 2008 | HP Photosmart 3310 Printer
UNLOCK SAGEM MY W-8
imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Oct 24, 2007 | Lands Phones
Olympus FE-280 Digital Camera Logo
151 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
