Question about Canon NP 6545 Copier
Code e532 what is it and can i fix it - Canon NP 6545 Copier
  • 231 Answers
Errors that start with a E5xx is usually a fault with the sorter or finisher accessory.
Check that the accessory is not jammed or incorrectly mounted.
Try disconnecting it to see if the copier works without it.
Posted on Apr 30, 2010
E000532-8001
E532 Main cause Stapler shift motor (M10) Stapler shift home position sensor (P16) Detection The stapler shift home position sensor does not go OFF when the stapler shift motor is driven for 4 sec. The stapler shift home position is not detected when the stapler shift motor is driven for 4 sec.
Sep 29, 2012 | Canon imageRUNNER 8500 Copier
Canon ir8500 with errir e532
that is the stapler is detected wrong position,
several possibility are :
- stapler empty
- just loosen
check it out....
but I have experience about it. and I just remove and replace the stapler.
and not error again....
good luck....
Jul 20, 2011 | Canon imageRUNNER 8500 Copier
HAS CODE E532 AND MESSAGE TO TURN OFF AND BACK ON
E532-1 Stapler guide bar motor E532-2 Stapler swing motor E540-3 Bin shift motor
Apr 01, 2010 | Canon NP 6545 Copier
Canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Wath can i do,if the machine Canon Image Runner 9070 send the follow error message: E000532-0001
Nov 16, 2009 | Canon imageRUNNER 8500 Copier
E532 in canon np 6560
Hello sir; That's not the staple problem, that's staple shift motor problem, replace it.
Sep 30, 2009 | Canon imageRUNNER 4570 Copier
Error Code: E631 & E632 on Canon NP6551
make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Oct 03, 2008 | Canon NP 6551 Black and White Copier
I HAVE TROUBLE WITH MY CANON NP 6251 IT ONLY DIPLY THE CODE NUMBER E 532
A E532 code deals with the sorter. Are the bins moving at all, also try to unjam the stapler. Also have you tried to let the machine warm up with the sorter moved away from the copier? How about this have you tried to turn the copier OFF then disconnect the sorters plug from the back of the copier and turn it back ON with the sorter moved away from the copier. If it works you are all set. I believe your copier is a older model and for the 10 bin sorter that it comes with may not be worth repairing. If it is a 10 bin sorter, it was never a good design from Canon, they work or don't work.. Good Luck...
Sep 28, 2008 | Canon imageRUNNER C3200 Copier
E532-0001
An E532 happens when the stapler unit either does not move from front to rear, or rear to front, or hangs up and stops part of the way. A broken stop gate can get in the way of a stapler and keep it from moving. Usually the two inside gates are the problem. The bottom spring may have fallen off when the plastic tab on the bottom of the gate (which holds the spring) breaks off. Or the parts of the gates that come in contact with the white rollers on the stapler assembly become dry and need to be greased to allow the stapler to slide past them. Also check the wiring harness that runs from under the stapler, through an opening and then connects to the stapler itself. Wires have been known to break internally at the wire-tys and cause erratic E532s. Check each wire with a meter for continuity. Hope this helps a little.
Jun 06, 2008 | Office Equipment & Supplies
Nothing is copying
E532 is a sorter problem. Have you replaced the staples recently? If so try to remove any jamed staples from the stable cartride and try to reinstall as shown on the inside of the soter front door. You can also try to turn the copier off and unplug the sorter and reattach it and turn on the power. See what happens, if that does not work and you don't really use the sorter, unplug it and detach it from the copier and make a exit tray and there you go. If you do use it call for service.
Feb 07, 2008 | Canon NP 6050 Copier
Canon NP 6545 Copier Logo
134 people viewed this question
old marine
old marine
