I need Fan for outdoor unit of 2 Ton AC. where can I get?
    New Friend:
  • 107 Answers
Look in the yellow pages under Air Conditioning wholesalers.
Posted on May 01, 2010
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
We have 2 ton split Ac elekta brand need out side unit fan motor conection daigrame please help us thanks
Most units wire up the same 1 or 2 capacitors to start compressor and or fan motor and a connection point for AC power and control wiring Here is a link to one of the better guides I know of http://www.alpinehomeair.com/related/AC%20Installation%20Guide%20Update.pdf their are quight a few videos on you tube on hooking up AC units also
Jun 27, 2016 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Will goodman outdoor ac work with bryant indoor unit
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier.
Apr 12, 2013 | Bryant 462AJC021BA Air Conditioner
Instal capacitor on Rudd 10Ajb24a01
Hi, this is a 2 ton unit from the numbers you have provided. I'm not sure what you are asking about the capacitor?? If you are installing the run capacitor, is it for the compressor/outdoor fan motor? I can't tell you how without looking at the schematics on the unit. Its pretty simple though. If you know its bad, you may have to purchase one online. You have to be a contractor in the hvac field to get one at a wholesale store. If its a dual run capacitor, it will have a c, fan, and herm stamped on top. This is for the compressor and outdoor fan motor. It will say something like this, ( 30mfdx5mfdx370 volts and so on. The 2 brown wires on the condenser fan motor will go one taped off and the other on the fan terminal if you are using a dual cap. If you are using a single 5 mfd or larger on a new motor, both brown wires will go to each side of cap. I will need more details if this is not what you need. Thanks
Shastalaker7
H,V,A.C. contractor
Ps, Send me more information on what you need?
Mar 19, 2012 | Heating & Cooling
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
Samsung 1.0 ton(split) AC stops working during 36-37 degree C.
i believe you have a high pressure switch on your condenser that is going bad .it is a switch that has two red wires connected to it inside your outside unit
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
