Question about Ford 8N Tractor
8N rpms keep falling
Hello.Just got my 8N running again(replaced points ,coil,resistor).It ran great for 2 days.Today it starts fine and sounds strong but when I move it goes about 10 ft and the rpms go way down and it wants to die.If I let it sit the rpms come back up after a minute or 2 and we repeat the scenario.Any help would be appreciated
  • denishouriha May 01, 2010
    Thanks to everyone who emailed.It was simply a matter of 1 fouled spark plug.Running great now
  • captjack163
    captjack163 May 11, 2010
    Have you checked your fuel bowl and is the fuel supply wheel turned all the way to the left?
    Problem Solver:
  • 13 Answers
I run one number hotter plugs in my N tractors as they tend to foul plugs.
Glad it was a simple fix.
Posted on May 01, 2010
When I push and hold the start button the tractor starts and stays running, if I release the start button it shuts off, if I remove the wire to the solenoid relay it stays running
It sounds like a "Load Resistor" problem, not sure if you have this type of starting system. The load resistor is in the wiring that goes to your coil after the engine has started. It is bypassed when starting to offset the loss of voltage when the starter is engaged and turning over the engine, then after the engine has started the "Load Resistor" is again in series with the points dropping the voltage slightly and providing longer point life. If this resistor burns out then you would be able to start the tractor but as soon as you released the starter foot switch the points/distributor would no longer have voltage. The Load Resistor is a large gray, brown or white colored rectangle ( 3" long and about 1/2wide aprx.) mounted on the back side of your dash panel....
Sep 01, 2014 | Ford 8N Tractor
1940 9n will not start, have replaced the points, condensor, 12 v coil, wires, new carb and the stark plugs. The only thing happening is gas coming out of the itake from the air cleaner. Also I replaced...
Is it cranking? Is there a spark? If there is no spark. I would look at the points again; unless you mean you replaced them now instead of in the fall. Look at the points and if they look frosted then try sanding them or replace them again. They can go bad quickly if there is moisture in the cap. Recheck the gap. It is possible that you got a bad condensor if the points are good. Check the cap and rotor for corrosion and remove this coorosion or replace them. Check that you have voltage at the coil. It might be a bad ignition switch. If all this is good turn the crank till the points close, turn the key on and check for a spark with the coil wire within a 1/4" of a ground when you open the points with a screwdriver. If it has spark; try spraying a little starting fluid into the carb. Let us know what you find out.
Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
8n (front mount distributor)seems to be frying coils, one day working just fine, next doesn't spark at all, New condenser, plugs, wires, rotor,points, distributor cap. Replaced coil last time seemed to...
Had the same problem, but was my fault for bypassing the ballist resistor (my bad). Anyway, I fried the coil. Read all the posts and bought new 12 volt coil (it has been converted before I got it 13 years ago). New points, condenser, cap, rotor. Now it is just my timing is a little off, but I have strong sparky but not enough to fry my coil again.
If anything, keep the ballist resistor. it is needed to drop the voltage to the coil so it doesn't fry.
Jan 12, 2010 | Ford 8N Tractor
1983 Porsche 944 coil goes bad, just replace coil
What do you mean by bad? Does it measure a different resistance.
Here is the thing on coils, I do not understand why they are not made differently, but
coils are to be run at a lower voltage, often. some like older cars, no more than 8 volts....Think about it...That is a LOT of resistance to scrub down to 8 volts, hello? the system is 13.8 to 14.9 volts NORMAL.....
But I digress.
These resistors fail and the amount that they should do, they cannot do.
One thing that I do as a diagnostic test is to buy a coil, any coil with an INTERNAL resistor. So, I can put full sysytem voltage to it....If it lasts, investigate the viotage available at the coil.
Doc
Sep 13, 2009 | Porsche 944 Cars & Trucks
1999 Buick Regal GSX won't stay running......
It's probably the mass airflow sensor and/or oxygen sensors.
Jun 18, 2009 | 1999 Buick Regal
Ford 8N will not start when hot
This sounds like a bad fuel pump to me. The only way to be sure is to check the fuel pressure when cold, probably around 45 PSI. Then when it get hot it will drop way down to 10 or 15 PSI. Check the pressure if you can, or change the fuel pump.
Jun 12, 2009 | Ford 8N Tractor
Idles rough ,loss of power ,sounds like its running on 2 or 3 cyl. changed fuel filter no diff. maybe a bad coil, 2003 beetle 1.8 turbo 4 cyl
I had this same problem on mt 2004 jetta. It had 85,000 miles on it. one day it bagan to idle rough but seemed fine when at higher sppeds/rpms. after a weekm I took it to the dealership and it turned out that a few of the coils/springs were shot. they also replaced my spark plugs, costing me about $550 total. But the car runs great again.
Aug 17, 2008 | Volkswagen Beetle Cars & Trucks
Ford 8N Tractor Logo
344 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
