Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
Lights dont stay on
We removed a regular light switch, not a 3 way light switch & installed a timer light switch. The direction say to connect the white (neutral wire) to the white on the switch. The black wire from the timer switch connects to the hot from the panel. The red connects to the load (wire coming from the lights). the ground from the timer switch i connected to the metalic juction box. We turned the power on & pushed the manual on & the lights come on but turn off right away. Same thing when the timer turns the lights on, they go off right away. Can figure out what the issue is.
  • 234 Answers
I must assume that when the light goes out (quickly after it goes on) that you can turn it on again very soon and the same thing will occur. This cold be an overload; that is, the timer is designed for handling 300 watts (as an example) and you have 400 or more watts of lighting, therefore the timer is saying this is too much and cutting off. Or there can be a bad light that is drawing too much electric such as a fluorecent light with a bad ballast. Or, if this outlet where the switch was, has only 2 wires that went to the old switch (and no other wires) then you may be feeding current into the new timer switch and shorting it out. The essential point is: is this switch outlet box with only 2 wires where the black and white both went to the switch, or are there more wires where 2 blacks (or a black & red) went to the old switch and the white wires are nutted together and not attached to the old switch.
You need to determine the wiring system within the box before you can determine how to apply them to this timer unit. Remember, the timer needs a nuetral and ahot just to operate, then it needs to feed this operated conrolled electric to the light via the red output wire. Regular switches do not work in this manner.
Posted on Apr 28, 2010
Intermatic/GE 15071 digital wall timer - Connection Problem
1) GE 15071 (Tork SS20) is single-pole timer, and cannot be wired as 3-way timer
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
2) Check wire nuts are tight
Remove light bulb and spray WD40 into socket. Reinstall light bulb
3) Reset timer using paper clip or tooth pick, then reprogram to see if functionality is restored
4) Move timer to different location and see if it controls different light
5) Buy another 15071 from home depot.
Remove bad timer, take photo of wires, and install new timer same wire-for-wire.
Return bad timer to home depot in new package.
This is GE's extended warranty plan, but do not mention warranty at return desk.
5) Intermatic and GE are fierce rivals in the timer business.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Intermatic makes their own products. GE timers are generally made by Tork. Both companies sell timers worldwide.
Feb 09, 2013 | Hardware & Accessories
I am replacing a programmable timer switch that controls exterior garage lights. This switch is in the same box as a ac switch that turns on the lights inside the garge. There are 3 rolmex wires inside the...
Project is not clear.
Are you replacing the timer with a switch?
I have complete files on timers, so if you are replacing the old timer with a new timer, then add a comment and say which timer you are installing.
http://waterheatertimer.org/ST01C-program.html
You have 3 cables. Assuming 120Volts.
Each cable has 1 black and 1 white and 1 ground.
White wires are twisted together and pushed to back of box.
Ground wires are twisted together and pushed to back of box.
Black wires are next:
(A) Cable A:
One of the three cables will have a black wire that connects to both the switch and to the timer.
So look for the black wire that connects to both switch and to timer.
This is the hot wire from breaker box. Connect this black wire to both switches including new switch.
(B) Cable B: One cable goes to garage lights. Black wire going to garage lights connects to on-off switch.
So the garage light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
(C) Cable C: One cable goes to outdoor lights. Black wire going to outdoor lights connects to new on-off switch.
So the outdoor light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
Jun 27, 2011 | Hardware & Accessories
I have a utilitech 7 day in wall digital timer and would like to install it but have no clue how to. can you get me started
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
See instructions along with image at following link:
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
SYLVANIA DIGITAL WALL SWITCH TIMER SA 170. NO DIRECTIONS AS TO HOW TO PROGRAM THIS DEVICE. WANT TO TO BE ABLE TO SET SPECIFICI TIME FOR OUTSIDE EAVE LIGHTS TO COME ON AND GO OFF.
Manual at Hardware Innovations Click manual link to right of product photo
Sylvania SA170 manual shows that timer can automatically turn on lights at sunset time, just enter your phone area code: Timer has to wired first and power on. Manual has long list of instructions starting on page 2.
How to wire timer:
SA170 replaces on-off wall switch that has 2 wires + ground
Timer has 3 wires + no ground wire
Wires that come off switch connect to Timer Blue & Black wires
Timer white wire connects with other white wires in box - if you do not have other white wires, connect to bare ground
If timer doesn't work, switch Blue and Black wires
Oct 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Installing a GE digital wall timer. Instructions say" connect Hot/live wire of main to black of timer. Connect Hot/live wire of load to red of timer. connect white of (neutral) to white of timer. green...
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Sep 25, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
The brake lights stay on it,s a 1998 ford escort
REMOVAL & INSTALLATION 1997-99 Models
  1. Disconnect the negative battery cable.
  2. In some cases, it may be necessary to remove the underdash panel to access the switch.
  3. Unplug the switch electrical connection.
  4. Unscrew the switch and remove it from the pedal. Fig. 2: The electrical connector (arrow) plugs directly into the brake light switch 90989g02.gif
    To install:
  5. Install the switch on the pedal and tighten the switch locknut.
  6. Attach the switch electrical connection.
  7. If removed, install the underdash panel.
  8. Connect the negative battery cable.
Sep 24, 2010 | 1998 Ford Escort
I have an ST01 timer that I want to place in a three way circuit that appears to be different than that shown in the directions. My circuit has power (black/white/ground) coming into switch 1 with a three...
One caveat of most In-Wall electronic switches/timers is that the device _must_ be installed at the switch box that has the power, in your case switch #1. In order to install it at switch #2, in your case, you need an extra wire between the switches (to carry the HOT wire), and unfortunately, the bare ground(ing) wire is not permitted to be used to carry current per National Electric Code (NEC).
In your case the wiring for the ST01 is as follows:
Switch box #1: Connect the incoming White wire to the White wire in the 3-wire cable that goes to switch box #2. Connect the incoming (Black) HOT wire to the Black wire on the switch/timer. Connect the Red wire in the 3-wire cable to the Red wire on the switch/timer. Connect the Black wire in the 3-wire cable to the blue wire on the switch/timer. Connect the green wire on the switch/timer to the 2 bare ground(ing) wires. If you have a metal box this connection should also have a pigtail that connects to the box with a green ground screw.
Switch box #2: Remove all of the existing wires from the 3-way switch. The three-way switch will have 2 screws the same color (usually black) and 1 screw (usually brass). For this scenario, one of the black screws will _not_ be used.
Connect the Black wire in the 3-wire cable coming from switch #1, the Black wire going to the lights, and a short Black pigtail together under one wirenut. The pigtail is then connected to the brass screw on the 3-way switch. The Red wire in the 3-wire cable coming from switch #1 is connected to one of the 2 black screws on the 3-way switch (pick one).
In effect you are installing a single switch at switch box #2. In fact, you can use a regular single pole switch if you want too.
To finish, connect the White wire in the 3-wire cable coming from switch #1 to the White wire going to the lights.
Grounding is the same as switch #1 except you'll need a pigtail to connect to the green screw on the 3-way switch.
That's it. You may want to check the battery compartment in the switch/timer, as sometimes they put in a pullout plastic tab to keep it from being energized until needed.
Now, the E1210 is a different animal, and can only be used to replace a single pole switch. You could use it by basically passing the power through to switch box #2 from switch box #1 and then cover switch box #1 with a blank plate. The ST01 could be used that way too, in which case the black on the device connects to the hot, the blue to the lights, and the red on the device is not used, nor will the Red wire in the 3-wire cable between the switch boxes be used.
Sep 11, 2010 | Intermatic EI210 Electronic Auto Shutoff...
One of my five EJ500C timers controls 6 outdoor landscaping lights behind my house. I installed the energy saving (coil type) bulbs and, at roughly 15 minute intervals after the lights come on at dusk, the...
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Feb 27, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
157 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
