Question about Samsung LA40A450 40 in. LCD TV
Lcd samsung TV LE40A436T1D stuck on standby mode it wont turn on the red light flickers when remote is pushed but nothing comes up. Its attached to the mains correctly but does not come out of standby mode any suggestions??
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My samsung le40a436t1d tv wont turn on, stuck on standby, help
Try pressing the up/down channel buttons. If this doesn't work, try replacing the batteries in the remote. If that doesn't work, pull out the plug, wait for ten seconds and then plug the TV back in. If it doesn't work after this, you should phone the warranty providers/repairmen to have a look.
Mar 15, 2011 | Samsung LA40A450 40 in. LCD TV
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Samsung LA40A450 40 in. LCD TV Logo
723 people viewed this question
Jerry Greenberg
Jerry Greenberg
