Question about Microwave Ovens
Microwave is completly dead. No display nothing. Fuse is fine in the Microwave and electrical is fine. Model SM80904. Is this a common problem with this model?
  • snoozecity Mar 26, 2008
    can you provide a picture of what this fuse looks like
  • snoozecity Mar 27, 2008
    Oh, I check that but that's not the problem. Thanks for your help.
  • 185 Answers
Check the themal fuse if that is blown nothing will work
Posted on Mar 25, 2008
  • Anonymous Mar 27, 2008
    its white and skinny about 1inch and a half long it has 2 connections to it be carefull you have to diapate the capacitor by touching the two prongs with a plastic handled or rubber srewdriver thats black and round and also has 2 connectors to it
6ya staff
SOURCE:
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
No heat, does not cook
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Microwave completely shut off, including the display
check the diode and the cap they like to go bad.good luck
Apr 06, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
228 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
