Question about Home
I just bought a Moen shower spa and was wondering how high the spray's should be set. Please help. \r\n Thanks!!
  • 20 Answers
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
The water is too hot coming out of the shower and if I turn the handle it does not cool enough. It is a Moen exactemp control.
You have the scald guard set to high. Take off the handle and the face plate. You will see a small plastic half moon looking part with teeth. Yours is probably set all the way one way which keeps the cold water side restricted and the hot side fully open. Carefully pull the half moon part out and rotate in about halfway and reinstall. That will give you equal cold and hot water flow. If that isn't right for your needs, you can play with the settings.
Jun 30, 2011 | Moen & One Handle Tub & Shower Faucet
I lost the install instructions for my Moen 270 exact temp shower kit.
Moen Chrome ExactTemp Vertical Spa:
http://www.moen.com/moen/chrome-exacttemp-r-vertical-spa/_/R-CONSUMER%3ATS270
Product Specifications:
http://www.moen.com/shared/pdf/ts270sp.pdf
Exploded Parts View:
http://www.moen.com/shared/pdf/ts270pt.pdf
Replacement Parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=TS270
Unfortunately the installation Instruction Sheets/Owner's Manual are not posted for the 270 models. Suggest you contact Moen Consumer Support directly to make a request:
http://www.moen.com/consumer-support/contact-us
Apr 02, 2011 | Home
How to tighten Moen Handle...Not leaking, just wobbles.
Replacement parts can be found on amazon, click here and take a look: Award winning faucets and shower heads. Have a nice day
Mar 12, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
Moen Refresh? Shower Head 3-Way Combination Pack I just bought this and am having problems with the install. The hose to the handheld leaks on both ends no matter how tightly it's screwed in.
Hi Rebecca,
Sorry to hear that your shower head hose is leaking. If you could please provide a few details to our Consumer Services team, someone can help you reach a solution. You can either visit http://www.moen.com/consumer-support/contact-us or call 1-800-BUY-MOEN.
Thanks
-Olivia from Moen
Jan 06, 2011 | Moen Home
Moen Hand Shower repair
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
My moen shower faucet has low hot pressure and high cold pressure.
Either your water softener has a clog or your hot water tank has sediment build up in it.Either way your looking at have a licensed plumer come out and give you an evaluation.
Mar 20, 2010 | Moen & One Handle Tub & Shower Faucet
Moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 29, 2009 | Moen 2919 Chateau Two Handle Tub and...
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
Home Logo
51 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
