Question about Cycling
Where should I set the chain for the easyest pedeling position?
    Brigadier General:
  • 8,546 Answers
You don't identify the bike so generic is the best I can do...
http://www.sheldonbrown.com/gears.html
http://www.jimlangley.net/crank/bikingskills.html
Posted on Apr 28, 2010
My brake light switch is broken
Its on the brake pedel you need to remove a clip from the end of the pin that slides through the pedel and the brake switch then the pin then the connecter . Install in reverse order .
However before removeing anything you should look to see if there is an adjustment for the switch . You see the brake light olny comes on if you push on the pedel most have adjustments on them because its an on demand thing so the light could be on if your not pushing the pedel or it could not come if you are pushing the pedel or it could not come on at all pushing or not pushing to pedel .You need to figure witch condution you actully have .
Mar 15, 2015 | Cars & Trucks
My 1998 200sx stopped accelerating while getting on freeway.
Could be the cable that actavates the throttle plate on the intake..
The cable comes from the gas pedel and pulls on the throttle plane in the intake manifold.. opening the plate to let air flow through to the engine. On the other side from the cable is a plastic sensor with wires attached to it this is the Throttle position sensor.. if this is disconnected or broken the computer cannot receive the single that you are pushing on the gas pedel.. very rare for the throttle position sensor to break completly.. best posibility broken cable.. open hood find cable connected to throttle body, have someone in car push pedel see if it moves. Good luck.
May 11, 2014 | 1988 Nissan 200SX
My breakes dont work till they are almost to the floor
Try pumping the brake pedel. If the pedel travel comes up, the rear brakes need to be adjusted. If the pedel does not come up, it could be a bad master cylinder or a broken brake line.
Jan 07, 2013 | 2001 Kia Sportage
How do you install the kickdown cable on a 97 dodge caravan
rotate throttle linkage cam to wide open position, remove cable from slot.squeeze the retaining ears togethet to remove cable from bracket. you will need a flashlite to remove cable from accelerator pedel disengage retainer from top of pedel.remove the horseshoe shaped clip from grommet at fire wall,work grommet out of hole then pull cable out from engine compartment side of firewall. install in reverse of removal
Jun 14, 2011 | 1997 Dodge Caravan
When I sit on bike and pedel bike will no go pedels seem like there stripped just spin something wrong with pedel bearing maybe
If it spins wihout spinning the rear wheel there is something not catching (chain, internal mechanism of the rear hub maybe). You need to LOOK at it and determine if the rear cog is indeed spinning with the chain or not. If it is spinning without the wheel the pawls or guts are not engaging. Take it to a Bike Shop and have them assess it.
Mar 27, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
My stop lights wont go off. Stay on all the tima.
There is a button above your brake pedel that probably isn't being pushed in all the way by the brake pedel to shut them off. Try pulling up on the brake pedel and have someone watch to see if they go off when you do that. If so the button for the brake pedel needs to be adjusted so it shut them off when the pedel is not pushed.
Nov 13, 2010 | 1997 Honda Accord
Bake light and binker light not working
You can check the flasher switch inside the fuse box its easly replaced or you can check the brake switch located on the brake pedel upper part under the dash or it could be the turn signal switch it self Myadvice is start with the easyest test first first and that would be the flasher unit upllug it from fuse and try a new one if thats not it check brake switch
Nov 01, 2010 | 1998 Ford Expedition
When peddling the pedels slip
Check your chain and see if you have a link that is stiff. If so, this can cause the chain to slip over the gears. You can try soaking it in oil or WD40 and once its free put some chain lube on it. Hopefull this will help. Good luck!
Mar 07, 2010 | Mongoose 20-Inch Gravity Games BMX...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
