Question about RCA P52960 52" Rear Projection Television
Rear projection tv broke
I have a 52in RCA rear projection and all of a sudden I have no picture. The sound works fine and I can pull up the menus and all. Please help.
  • RCA Master
  • 8,617 Answers
Try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Posted on Mar 24, 2008
SOURCE:
The sound stopped working on rca projection TV
FBT flyback transfomer and hori output transistor
Jan 01, 2010 | RCA P46812BL 46" Rear Projection...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Picture no sound
If you will look I bet you'll find a switch on the back of the TV for internal or external speaker. It's probably gotten switched to EXT. somehow.
Dec 27, 2008 | RCA P52937 52" Rear Projection Television
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52in screens
I have a RCA P52937 I could part out, the screens are fine so let me know if you still need.
Jun 24, 2008 | RCA P52926 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Screen dont work
proabably it,s because you left it on for long time , or the image power saver is wrecked and damaged after a storng lightinning , and if you have cleaned ther tv screen with a wet wiper it causes that to happen
May 11, 2008 | RCA P52937 52" Rear Projection Television
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
