L17AMTN 17 in. Flat Panel LCD Monitor: monitor starts. shutts off after 10 secs. displa...
Monitor starts. shutts off after 10 secs. displays messge "can not find signal"
  • 11,361 Answers
It is telling you that it is not getting he signal from your video card, so please check to make sure the VGA cable and all the pins at both end of the connectors are OK, try reseating the video card. Try this monitor with other PC. We need to narrow down the problem. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 28, 2010
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
I have a Tatung lcd flat screen monitor tv. The television comes on there is sound but the screen is black. The tv is 5 years old. What would cause this?
Failed backlight inverter circuits or the power supply for the backlight circuits has failed, you need to open it up and inspect the power suply first, look for bad caps with leaking/bulging tops. Post back what you find so we can guide you further.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Tatung l17amtn lcd monitor
check the desktop and display settings from the control panel,, then from there go to screensaver and power,, make all to never and make your screensaver also to none.. and see
Sep 29, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
