Question about Plumbing
Water does not stay hot... - Plumbing
    Problem Solver:
  • 7 Answers
New hot water heater
Posted on Apr 29, 2010
My hot water heater on my 5th wheel heats up in electric and gas but doesn't stay hot. It is hot a first then gets warm and then cold. Hope you can help.
The thermostat which is integral to the gas valve is defective. Simply replace the gas valve and your problem will go away.
Dec 15, 2015 | Water Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
Our hot water isnt staying hot for very long
Probably electric water heater/
Test elements, if elements test out, then replace both thermostats
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment march 2013 and say which brand and type heater
Mar 11, 2013 | Water Heaters
The burner on the heater is working bu can't get water to stay hot at the faucets or showers water turns cold right away. whats the problem?
Test for crossover, where bad faucet cartridge or recirculation check valve keeps hot from reaching taps
http://waterheatertimer.org/Crossover.html
Add a comment and say what you find
Feb 28, 2013 | Rheem Water Heaters
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
I have a nortiz 063-s tankless, and it won't stay on...I'm thinking it's the computer, please help
There are several things I would look for:
-Flashing burner light (indicates an error code)
-Trying flowing more hot water. In the summer alot of times you'll flow less hot water because your cold water is warmer. If you flow additional hot water at your shower, it will ensure the unit stays firing
-If the unit doesn't fire at all, you may have debris in your cold water filter or a stuck flow sensor. Call tech support to help you with cleaning a flow sensor.
May 29, 2010 | Noritz 6.3 Gallon Residential Tankless...
Hot water pilot light statrts but will not stay on. There is a new thrmo couple
Please confirm which model you have. Heading says DSI (electronic ignition) and it sounds like you are describing a manual light with thermocouple?
May 21, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
What to do if water gets inside hot water tank fluke..and what may happen when the tank fire dont stay lit?when tryinig to lite it
sounds as though you need a "thermo-couple" replacement to make the flame stay on,.......tryin to keep ya in hot water, cracklin joe
Jan 04, 2010 | Emerson InSinkErator C1300 Chrome...
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
Jul 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
