Question about NEC Electra Professional ETW-16DC-2
DO NOT DISTURB (DND)
NO ONE CAN INTERCOM ME BECAUSE MY PHONE HAS A DND CODE ON IT - HOW CAN I RESET IT?
  • queenjean45 Apr 08, 2008
    So so so appreciated. Thank you
Without lifting the handset press FNC 99 FNC
Posted on Apr 09, 2008
Press FNC 69 FNC
Posted on Apr 08, 2008
SOURCE:
Kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
How to cancel dnd cancel
The Panasonic 77xx series phones was first delivered with the TA series systems, but the phone is both forward and backward compatible with 7 different prefix phone systems and about 18 different models.
In a TA series, from the intercom, press FWD and dial 0#. It will turn BOTH Forward and Do Not Disturb off, so if you are forwarding calls to VM, you'll have to reset it.
Carl
Jul 04, 2011 | Panasonic KX-T7730 Corded Phone
How do I turn the intercom off at an individual handset?
Do you mean intercom or paging? You can turn off paging by setting the Paging Deny code. From the intercom dial *7211 with 10 being the allow code. As far as the intercom, onlly Do Not Disturb (*7121) will fix that (as always change the 1 to 0 to allow). The DND light will light solid and when you press the button, the display will give you information as to what is set.
Carl
Jun 16, 2011 | Panasonic KX-T7630 Corded Phone
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
How do I turn Do not disturb off
It really depends on which one of group of up to 18 cabinets your 7731 is connected with, but in a TA series, 714# on the intercom sets, 710# clears. You can also press Intercom the FWD/DND button and dial 0#. (or 4# to set it again)
Carl
Oct 02, 2010 | Panasonic KX-T7731 Corded Phone
My Intercom Extention shows busy. I have
With the exception of not being to dial out, it sounds like your DND or do not disturb button is on,The feature can be turned back off by either pressing the DND button again or entering feature #85.
Nov 27, 2009 | NorStar M7310 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
My unidin is saying dont disturb
To cancel the DND feature, press do not disturb again. (this is either a key on the base unit, or can be found in the Menu on the base) You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
Jul 02, 2009 | Uniden 5.8GHz Dual Cordless Phone
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
NEC Electra Professional ETW-16DC-2 Logo
305 people viewed this question
Top NEC Lands Phones Experts
Steve Allison
Steve Allison
Ekse
Norman Al-Anbar
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
