Question about Rowenta Effective DX1700 Iron with Auto Shut-off
Not heating The red light is not on and the iron is not heating.
  • Anonymous Apr 27, 2008
    I have a panasonic and it won't heat up but you can feel the heat in the handle
Need tools for rowenta iron DX1700. Where could I purchase?
antonio_so671
Posted on Jan 06, 2010
  • 304 Answers
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Posted on Jul 24, 2008
4 Suggested Answers
bestdarngood
  • 3037 Answers
SOURCE: Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Posted on Mar 29, 2008
  • 2336 Answers
It looks like the cord has a loose connection and will need to be replace.
aviral_srms
  • 1216 Answers
SOURCE: Iron will not heat. Iron worked last week, went
the heating element has failed....probably
You would need to open your iron to test the thermostat:
Open the Iron up. Use a volt meter to test the thermostat and heating element. With the thermostat turned to a high heat setting. It won't matter which electrical connection at the thermostat you place the probes on, just put one on one side and the other on the other terminal at the thermostat. If you find continuity(Meter needle jumps, or digital read out show little or no resistance found) your thermostat is ok. Then place your probes across the two leads on the heating element. You should read little or no resistance. Any parts found showing an open open circuit(Zero on your meter) will need replacing.Contact small appliance.com and they should be able to order one for you. If there is anything else I can do for you please don't hesitate to ask.
Posted on Jun 25, 2011
Iron is plugged in but no red light no heat no nothing
Oct 10, 2016 | Irons
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Iron won't heat up, the 3 lights of yello green and red blinking
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 03, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Irons Logo
735 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
